Diesel in my crankcase
I am getting diesel in my oil. I have a 2008 6.4 diesel. Ford knows about this but I'm not getting any answers from the dealership. I've talked with a salesperson, mechanic, and service manager. I have a warranty and extended warranty but fear that the engine will fail after warranty is up. Any comments/suggestions would be appreciated.
Its somewhat common to get a higher than normal (whats considered normal anyway) amount of fuel in the motor oil on the 6.4l. I would suggest posting down in the 6.4l section. There are several other threads on the subject that should help you.
6.4L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Usually the cause is from the regens. Regens plus low speed operations/city driving are a killer to the process leading to most of the issues of growing oil.
There can be other causes though. Such as leaking injectors.
To help combat this growing oil it is best to change your oil every 5K miles.
As far as how much oil you are making can vary per user. I usually make .<5% due to my duty cycle and use.
So how much oil and have you done any oa's.
How far apart are your regens?
Most of our driving is in town. I made over a quart in 2000 miles. I don't know how far apart the regens are now. There was a recall to recalibrate engine warning approx. 6 months ago and ever since then, I do not see the exhaust cleaning on the dash. The dealership has checked and said that even though I don't see it it is happening. I change my oil myself every 4000 miles and check constantly.
the design of the motor requires heat to create the best seal around the rings. The best seal means less fuel dillution in the oil.
Running on the hwy or heavy towing creates the seal needed to keep the fuel dillution down.
City driving is your enemy with the emissions stuff.
There is not alot that can be done unless your dpf falls off in your case.
The Best thing to do in your case is ( When your warranty goes up) to delete your DPF, EGR, and CAT and get a H&S tune or Spartan tune. This will stop your oil growing problem. Especially since you do a lot of city or stop and go driving.
My truck is completely stock and I don't have the oil dilution since 95% of my driving is highway driving.
You may not be interested in doing this much work but when I had the DPF on I had success with the following oil program: Changed oil every 5000 miles. I installed a fumoto oil drain in place of my oil plug. Every 1000 miles between changes I would drain down to one quart low and add a quart of fresh oil. That program resulted in keeping the growth under control and improving the results from the oil anaylsis. I got it down to a 15 minute job. Hardest part was reading the oil level on that goofy dip stick.
I now have 4500 miles on my delete and oil is checking normal and much cleaner than stock. Hope this helps.
Fuel
Are you guys saying that fuel will mix into the oil even with no DPF/Regen just because of stop and go city driving? Don't engine temps spike higher when in stop and go traffic? Also, doesn't running a high horsepower tune put additional stress on the engine to actually make it work harder than the same engine running the stock tune? Wouldn't this additional stress actually promote better top ring sealing?
