how to change the engine
Hi i have to change the motor on mine 2004 f 150 some suggestions thanks
Is 5.4 ext cab 4x4 and im replacing whit the same engine but remanufactured my old engine as low pressure on the top end so they told my to replace the engine even if was just the cam phasers i was cost me 5000$ to do the job,some people told me to replace the engine you have to lift the cab that true?Im starting to taking it out tomorrow so any tip will be helpfull thank you.
thank tooldad
thank tooldad
While they are pricey, one of the absolute best resources are the actual/genuine/official Ford shop manuals. Helm, Inc. is the official source for them, but you can also search around other online sources like eBay & Craig's List to possibly find them at a cheaper price.
It has been my experience that the manufacturer's shop manuals far exceed the normal competition like Hayne's & Chilton's manuals in terms of details, topics, and overall completeness.
Good luck!
Good luck!
The problem is not the parts is I have low pressure on the top end the parts they are only 400$ but if I ad to change just the cam phasers the cost was 5000$ and in my town nobody will do it they said to me " bring to ford"because Is a big job and riski.one advice change the oil often and kee track a the oil pressure that's how the cam phasers the go no lots oil coming true.
Most dealers charge about 1400.00 to replace the phasers for both sides. Its an easy 5 hour job.
To replace your whole engine,well its really straight forward just bolts hoses and wires. I would strip all the front accessories off first to make it easier. Remove the radiator and battery. Tie the a/c pump to the frame so you don't damage it. Remove the starter and the exhaust. Remove the hood and then its easy sailing from there. This job should take 6 hours to R&R for someone with decent skills a little longer if its your first time.
Thank you everyone the old motor is out and the new one is in and just for curiosity I take the oil pan from my hold one and I find broken piece of the time chain rail and I take the valve cover and the cam phasers they are all black I gess the old owner he never change the oil sucks but the new one is in tomorrow is time to started
mxer0022
09-23-2016 11:20 AM
Ak_ford400
09-14-2004 11:29 PM
