Is this too many gauges?
With my 1 nicely and neatly mounted ODBII Aeroforce Tech Gauge on my V10...I get more information at my fingertips than I can display...although it only displays 2 parameters at a time...I can easily scroll thru all the parameters in less than a few seconds if needed.
Differential temps could be fed into one of the 2 analog inputs provided if desired...as could a pyro sensor...
If you take notice on my dash gauges...you will see little white marks...those are made by me with a simple grease pencil...that is the mark that the gauge "normally" sits at when towing/driving...so at a quick glance at my gauge cluster...I can see if the gauges are in their "normal" position because they should be just behind that little white grease mark...
For those that don't think the trans temp factory gauge actually moves...it will...but not until after 220°'s (see this picture that portrays movement...it was posted years ago by someone that experimented with the temp sensor)
My crude and rudimentary grease pencil mark is a very simplistic way to make sure the gauge has not moved even a little bit...because (without the mark) if the gauge were to move slightly...you may not notice it...and with how "narrow" a range Ford put in on that gauge...small movements once you hit 220° would need to be noticed...
Take notice that my white mark on the upper right gauge (trans on my cluster) coincides with the 100-220° photo needle position...
Joe.
Joe.
My race car has a tach, water temp, oil pressure, oil temp and fuel level. But fuel is not important if you're not running endurance races.
The much more varied demands of a hauling/tow vehicle necessitate more instrumentation.
I'm leaning towards an Edge Insight in a dash pod. Anyone got pics of one painted and installed? I was thinking of going with the CTS because of the big screen being able to show more at once but I don't like the way it uses an adapter to clip in tot he dash pod so I might just go with the CS that will fit flush in the pod and just scroll through gauges if I need to.
#28
Just another possible option of a tuner AND scan gauge option out there...plus the tunes from Mike at 5-star are excellent for V10 applications...which I'm not sure what engine you have in your ride...
Joe.
#29
I've got an SCT-X3...had I done more research and had more advance planning...since I wanted a tuner for towing...in hindsight...I likely would have gone with an SCT Livewire...which gives you a tuner AND an OBDII scan gauge that monitors and displays vehicle functions as you drive...you would need to keep the tuner plugged into the OBDII port all the time...but I keep my Aeroforce plugged in now...
Joe.
Joe.
#30
