1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
data plate decode
Old 01-05-2012, 05:37 PM
major562's Avatar
major562
major562 is offline
data plate decode
I have a 1962 unibody vin/ f10JH206883 with data plate in glove box wb 114 color L model f-100 trans A Axel 11 114 hp @ 3600 rpm. I think it is pretty much original except it is now green and white. It looks like a 223 straight 6 with 3 on the tree. Is trans code A a light duty 3 speed manual and what is axel code 11. Also does color L mean Holly green only. also the cover around the speedometer and gauges is white. Would it originally have been green or chrome. I only found this forum a few days ago and love it. Thanks for any info. John
Old 01-05-2012, 10:00 PM
Bill W's Avatar
Bill W
Bill W is offline
Hi John, Welcome to FTE!
okay, lets start with F10"JH" J=223 I6 and H= built in Lorain Ohio. "206883" built in Febuary 1962, Color L= Dark Green Trans A=3 speed standard. Axle code 11= 3.70 to 1 gears, 9 inch rear. white would be the correct color for the dash speedo if it's not a custom cab truck, custom cab's have a chrome piece.
Good Luck with your new project.
Old 01-06-2012, 06:44 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by major562
I have a 1962 unibody. VIN: F10JH206883 with Warranty Plate in glove box: W.B. 114 / Color L / Model F100.
Also does color L mean Holly Green only.
Welcome to FTE
VIN series code, first 3 digits: F10 = F100 2WD
114" Wheelbase.
Model F100 = F100 2WD, 5,000 lbs. Gross Vehicle Weight Rating.
L = Holly Green (Ford promotional name) / L = Dark Green (actual color).
Old 01-06-2012, 08:49 AM
major562's Avatar
major562
major562 is offline
Thanks for the help. Just trying to learn as much as possible about the truck. I just started working on it. I am about to order a shop repair manual. Besides this forum are there any books, magazines or articles you would reccommend before I begin any serious repairs to the truck. I just tuned it and got the lights working. Compression on the cylinders is between 82 and 100. I plan on keeping the truck close to original and start on the brakes so I can drive it a little and then try to deal with the body work and rust. Thanks again. John
Old 01-08-2012, 10:37 AM
kjvforme's Avatar
kjvforme
kjvforme is offline
F10JH206883 should be August of 1961 assembly date, my database has you having the oldest 1962 Unibody so far that I have recorded. The first built being 205001, that makes your truck 1,882 built for 1962. congratulations
Rob
Old 01-08-2012, 02:37 PM
major562's Avatar
major562
major562 is offline
thanks for the info.
Old 04-04-2012, 06:54 PM
NewtonsApples's Avatar
NewtonsApples
NewtonsApples is offline
Data Plate Decoder
Old 04-04-2012, 11:21 PM
kjvforme's Avatar
kjvforme
kjvforme is offline
At the top of the page under article/specs. If you want more post the info off of the warranty plate and let us take a look at it.
cowmankev
10-06-2013 07:47 AM
jakenney
03-01-2012 07:28 AM
dblewis
11-25-2011 08:40 PM
motion500
04-12-2010 06:03 AM
Tidefan88
02-16-2010 01:14 PM
Quick Reply: data plate decode
