Timing Chain Replacement - Alignment Marks?
Old 01-05-2012, 03:14 PM
rickm15752's Avatar
rickm15752
rickm15752 is offline
Hi all,
I'm replacing the timing chain on my 1989 E150 302. I'm doing this since the timing cover gaskets are shot and I thought since I'm in there I would just replace the chain and gears too.
I've not taken the old gear set and chain off yet. I'm trying to line up the marks according to my Haynes manual. The crank mark is perfectly at 12 o'clock while the cam mark is slightly off of 6 o'clock. It looks real close but they are not exactly opposite. If you put a straight line on them they do not line up perfectly. How close do these marks have to be? Do they have to line up precisely? Or can they be ever so slightly off and a timing adjustment at the distributor can do the final?
Also, I used a trigger switch connected to the solenoid to bump the motor to align the marks. Is that that suggest way to align the marks? Is there a better way to do this without removing spark plugs?
Thanks for your help.
Rick
Old 01-05-2012, 04:30 PM
blageurt's Avatar
blageurt
blageurt is offline
They should line up perfectly... unless your chain has stretched tremendously ....just make sure you install the new chain / sprockets exactly by turning the crank with a big box end wrench on the Harmonic damper nut and make sure Cylinder # 1 is at Top dead centre...
Old 01-05-2012, 04:36 PM
rickm15752's Avatar
rickm15752
Hi Blageurt,
Thanks for the reply. I removed the balancer, and now the old sprockets and chain remain. I guess I can reinstall the bolt that holds the balancer on the crank and then put a box end on that to get it precisely aligned. Is that how it's done?
Old 01-05-2012, 04:57 PM
blageurt's Avatar
blageurt
blageurt is offline
Thats what I would do
Old 01-05-2012, 05:00 PM
rickm15752's Avatar
rickm15752
Done! And now the marks are aligned precisely. Thanks again.
KenReb
Modular V10 (6.8l)
12-24-2017 04:30 PM
Finger__Rachet
12-17-2012 10:35 AM
Badfunkn
1997-2006 Expedition & Navigator
04-26-2012 02:21 PM
firerescuejason
1997 - 2003 F150
12-31-2007 01:12 PM
Superdave
15
09-30-2002 04:53 PM
Quick Reply: Timing Chain Replacement - Alignment Marks?
