2006 F350 5.4 Charging issues
Ok first, great site. I used it a few years back to do research before I bought my F350 and F250, the 350 is a dedicated work truck with a dump bed on it the 250 is personal/work.
I searched the forum for an answer but did not find one so PLEASE HELP!
The problem I'm having is with the 350. It is a 2006 5.4 dually with a dump bed. A couple years ago it started intermittently charging the battery. It would start fine, then drive to the job and try to start it and nothing, I would have to jump it.Then drive to the next job and it would be fine. At first I thought battery and replaced it. That worked for awhile then it did it again. I disconnected the dump bed and the problem still occurred. I checked the connections to the alternator and they seemed fine but after I did that I had no problems for a few days but then they came back. Gauges and everything else works fine work fine.
Thanks in advance
Thanks in advance
billenglish61
1999 to 2016 Super Duty
11-22-2015 01:45 PM
