PVH Solenoid Question
When I would turn the key on my Excursion, to warm the glow plugs, I would hear a pumping like sound like a vacuum pump. I am assuming that is the pulse vacuum hub lock solenoid. Well recently I was in a situation to where I needed to switch on the ESOF 4X4. Come to find out that the 4x4 did not engage. I then noticed that the PVH lock solenoid quit making that pumping noise. THen it was intermittent and now not pumping at all.
I am assuming the PVH pump is bad? There is juice at the connection. Any one else have this issue/symptoms?
98-Ranger
1983 - 2012 Ranger & B-Series
01-17-2012 02:30 PM
