1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
PVH Solenoid Question
Old 08-03-2010, 08:38 PM
Big Sky's Avatar
Big Sky
Big Sky is offline
When I would turn the key on my Excursion, to warm the glow plugs, I would hear a pumping like sound like a vacuum pump. I am assuming that is the pulse vacuum hub lock solenoid. Well recently I was in a situation to where I needed to switch on the ESOF 4X4. Come to find out that the 4x4 did not engage. I then noticed that the PVH lock solenoid quit making that pumping noise. THen it was intermittent and now not pumping at all.
I am assuming the PVH pump is bad? There is juice at the connection. Any one else have this issue/symptoms?
Old 01-03-2012, 12:57 PM
twhorse60's Avatar
twhorse60
twhorse60 is offline
Did you figure out your problem
I have a 2001 F350, Vacuum pump working, power to center wire to pvh-solenoid harness whether switch on dash is in 2wd or 4wd. The vacuum goes into pvh-solenoid, but none comes out. I replaced solenoid, and it didn't help.
HearseDriver
10-15-2015 05:24 PM
Blue7.3
Australia Chapter
21
08-12-2015 10:19 PM
HearseDriver
Modular V10 (6.8l)
07-20-2015 12:43 AM
jeem
09-16-2013 09:05 PM
98-Ranger
1983 - 2012 Ranger & B-Series
01-17-2012 02:30 PM
Quick Reply: PVH Solenoid Question
