Modular V10 (6.8l)
Excursion V10 - best modifications to increase performance
Old 01-14-2012, 03:21 AM
Xv10's Avatar
Xv10
Xv10 is offline
dkf,
thanks for your advice!
the the bottom line is that I will need to go for a 'roots' supercharger, which then will also require a modification/strengthening of the transmission, driveshaft and any other load-transmitting powertrain components to withstand the load from the increased power...
Old 01-14-2012, 03:26 AM
Xv10's Avatar
Xv10
Xv10 is offline
Originally Posted by samsdad02
if you do a gear research most people here think that 4.56 is a good starting point with stock size tire (32") if your running 35"s bumping to 4.88 or 5.13 would do you a world of good. if you decide to change gears let me know I'll buy your old set as I run 235's but would love a set of 4.56s ;-}
samsad,
I just replaced the stock gears by a 4.56... let's see, maybe I'll want to get a 4.88 or 5.13 some beautiful day... I'll let you know
Xv10's Avatar
Xv10
Xv10 is offline
Originally Posted by reaper75032
a few other mods you can do is get a larger set of injectors , a larger throttle body and take your truck somewhere they can do a dyno tune to it.. tht will get the maximum HP from it
reaper,
OK, noted with thanks!
Old 01-14-2012, 12:54 PM
rkloehn's Avatar
rkloehn
rkloehn is offline
the best way to add hp is to throw a blower(kenny bell, vortech, paxton, procharger) on it but you just cant bolt up a blower and think its going to run right. you will also need more fuel via larger injectors and if your making too much hp you may need a new fuel pump. the next thing you have to do is get the truck tuned on a dyno by a reputable tuner using an sct chip or something of that nature this step is the key to making good hp numbers and having good drivability. your drive train will be absolutly fine as long ans you dont go crazy hp. hope this helps
Old 01-15-2012, 09:30 PM
reaper75032's Avatar
reaper75032
reaper75032 is offline
one thing that may help in the future a little bit. is go with another brand tire.. ive had the nittos and they seem to be alot heavier than most mud tires... which will increase rotational mass
Old 01-15-2012, 09:46 PM
9mpg's Avatar
9mpg
9mpg is offline
Anyone know if it is possible to put high compression pistons in the 6.8 v10? I was thinking there might be a lot of power hiding in there if I could find some 10.5 to 1 compression pistons and run premium fuel. Stock compression ratio is 9 to 1 right?
I think the displacement decreases if high compression pistons are installed.
I am at 112k and adding 1 quart of oil every 2,000 miles so at some point down the line (far far down the line) I'm guessing it will get bad enough that I'll need to get some new piston rings. Why not change the pistons while i'm at it?
Old 01-15-2012, 10:10 PM
reaper75032
you will prob be into sooner than you think.. you should go through about a 1/2 quart every 5000 miles... so if your burning a whole quart every 2000 miles... 2.5 qts an oil change.. your rings or valve seals are leaking big time.. as to your question . ive never seen high compression pistons for the v10.. but you can do a throttle body, injectors, and an SCT or dyno tune
Old 01-19-2012, 12:35 AM
Rosson03's Avatar
Rosson03
Rosson03 is offline
Originally Posted by Xv10
Hi everyone,
I have a 2004 Excursion V10 4x4 with a 4" ProComp suspension lift, 35"x12.5" Nitto Trail Grappler tires (315/60/20) on 20x10 Moto metal MO951 chrome wheels, 4.56 gears, single-in-dual-out Flowmaster Super 44 muffler, and a Banks cold air intake, Banks headers, Banks y-pipe, and Banks Ottomind programmer.
I am neither towing anything nor off-roading, and mpg does not matter to me. I would like to get significantly better acceleration from start-up. Between 6 to 7 seconds on 0-60 mph would be great.
Any ideas what I could/should do to get this? Thanks!
I used:
try BBK DUAL 65mm TB and jet spacer. make sure u dial it in right or u will hate it. jet mass air flow
I want
also Flex A Lite Fan#294 the primary one (u free up more horses quickly and MPG!!!)
and i know how to get all this for $1,027.48 with free shipping! on a website.... not mine! i dont sell anything! thats a good deal i think!
Old 05-28-2016, 06:05 PM
SatinBlack03's Avatar
SatinBlack03
SatinBlack03 is offline
looking for anybody with the bbk 65mm TB, how did you get it tobe dialed in? I've been messing with the idle screw from day one and still can't get the gas pedal to not stick. How well does the jet chip work with it? I have it to the best point I've found that I can drive it comfortably but still sticks at a full stop.
Thanks guys, have a great weekend.
vee10td
Modular V10 (6.8l)
12-10-2010 12:32 PM
RookieRecurve
Aftermarket Products
03-05-2010 07:46 PM
Billinvancouver1
Modular V10 (6.8l)
05-10-2007 02:41 PM
KEEBS
Modular V10 (6.8l)
11-15-2003 08:47 PM
cinnpass
Modular V10 (6.8l)
27
01-06-2003 07:48 PM
Quick Reply: Excursion V10 - best modifications to increase performance
