Another Ecoboost failure story
#151
Every 30K???? I put 217,000 miles on my 2011 before replacing plugs, and have 111,000 miles on my 2013 with original plugs.
I do plan on changing these out sometime soon since i get about 3 mpg's less per gallon on my 13 compared to my 2011. Both trucks have teh same engine and 3.55 gears.
There are a LOT of folks out there with more than 80,000 miles on their factory plugs without issue. Not everyone goes that long, but to declare this necessary for everyone seems a bit over the top to me.
#152
We gap all of our plugs at .030. For heavily modded vehicles we will move the gap to .028. We've seem new and driven vehicles alike come in with gaps ranging from .028 to .056. Gap is quite diverse given the condition of vehicle and how hard they've been driven. All of our plugs come out at 30K intervals. Could we go a bit further sure, but a quick change keeps the vehicle running in top notch shape. The owners manual saying 100k is a stretch but I know many will use that as the measuring stick.
#153
Plug tip erosion is dependent on varying factors in every engine.
How it is driven, the compression ratio, pressure rise from turbo charging,
plug tip metal composition, spark intensity, heat range and other factors.
It does not hurt to change more often to keep performance at near top.
As for reducing tip gap it may help ignition and keep the plug in play somewhat longer as a benefit.
Erosion of the tip requires increased spark from the coil to fire reliably under increased cylinder pressures.
The voltage at which the spark occurs is dependent on cylinder pressures and mixture richness.
These vary continuously while driving.
The reduced gap may have an effect on idle quality.
The 100,000 mile mark is mainly a sales pitch that uses plugs made with much harder metals that resist tip and ground strap erosion much better at the 100k mark .
They cost more and in some engines are harder to get to.
Each time a spark occurs a little metal is lost. It's a normal action due to the high temperatures of just the spark it'self then add combustion temps to it.
Good luck.
Goodmluck.
Good luck.
Goodmluck.
#154
Deb Cablao
15
11-04-2015 12:58 PM
CosmoStarr
34
06-20-2010 04:08 PM
