Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Lift Kit Reviews
Reviews and comparisons of top products
Rancho RS6525 Lift kit on a 2011 F250
Hello to all of you,
I've been looking around for a good small lift kit for my truck,a 2011 gas F250.
I would like to know the benfits of a radius arm kit like the Rancho RS6525 wich should give me a 2-1/2" front lift.This kit is a lot more expensive then most levelling kit using spacers on front coil springs;Is it worth the difference?
I'd also like to know if the ride on the Rancho kit will be better,should-I expect a longer suspension travel?
I am planning on using F350 blocks in the rear. To run 35X12.50 tires.Does it sound like a good set-up?Will I have warranty issues with such a set-up?
Thanks for your comments.
Jo
Jo
The Rancho RS6524 (4") and RS6525 (2.5") are NOT "complete" lift kits... it is simply a replacement radius arm kit that should be considered an "optional" component. Both kits require new front coil springs (where the actual lift occurs) and new shocks. The 4" lift kit requires a rear "Axle U-Bolt Kit" which includes an auxiliary spring (2), blocks (2), and u-bolts. In short, when you ADD all of the required components, these completed kits are expensive.
RS6525 2.5" Lift Kit:
http://www.gorancho.com/images/suspe...eling_Sell.pdf
RS6524 4" Lift Kit:
Rancho Suspension: Suspension » 2011 F250 / F350 Super Duty 4WD Suspension Systems, Lift Kits, Leveling Systems & Shocks
IMO, only those aftermarket radius arm kits that are "adjustable" add value to a lift kit. Those that are NOT adjustable are the same as the OEM radius arms and are only for looks, not function. Below are two examples of functional radius arm kits in the aftermarket.
Icon 4-Link System:
61500 - '05 - '09 Ford Super Duty 4-Link System - ICON Vehicle Dynamics
OUO Adjustable Link Arms:
One Up Offroad Adjustable Link Arms - 2005-2011 F250/350/450 4wd - One Up Offroad Suspension Components - Truck Toyz Store
RS6524 4" Lift Kit:
Icon 4-Link System:
Thanks for the infos Furian ,
I've been looking at Rancho's kit with all the required hardware.It comes expensive as you said.
I assume that the radius arms must be different then the original to accomodate longer coil spring resulting in 2-1/2" or 4 " lift depending on the kit.
I am looking at the idea of putting a complete 2-1/2" lift kit on the front and using F350 blocks on the rear.
Can you tell me the main difference between an adjustable radius arm kit like Icon compare to other "straight" aftermarket radius arm like Rancho or Procomp K4176.
Icon seems pretty expensive too.
Thanks,
Jo
Thanks,
Jo
The adjustable radius arms have "heim joints" that replace the cam bushings. The heim joints can be adjusted for any application.
The Rancho RS6524 and RS6525 radius arms may have been designed with the applicable lift (2.5" or 4") in mind. They may or may not require cam bushings... you would have to contact Rancho to make this determination.
It may be a while before anyone installs these leveling/lift kits. Why?
1. They are relatively new kits from Rancho.
2. They are for the 2011 & 2012 Super Duty trucks. These trucks have larger front wheel wells so a leveling kit is not required to run 35" tall tires.
3. They are little expensive when compared to other aftermarket leveling kits.
Hang in there...
Hang in there...
Last edited by Furian; 01-09-2012 at 09:58 AM. Reason: Changed Skyjacker to Rancho
BTW, what IS the actual cost for everything needed for the Rancho 2.5" leveling kit?
BTW, what IS the actual cost for everything needed for the Rancho 2.5" leveling kit?[/quote]
I've been looking around for a while and I finally got a price today;
the basic RS6525B kit is 1050$ canadian,does not include shocks and coil springs.I found out that it is very difficult to even get a quote in Quebec.I know retailers from the USA have way better prices,but most of them ship trough UPS and this is where we get caught,it can add up as high as 40 % broker fees with those guys...
Thanks for your wise advice,I think I'll go with tires first and see how it works and how it rides.
Thanks again.
Jo
Thanks again.
Jo
Jo, I didn't realize that you live in Canada. I know of two companies here in the US that offer competitve pricing on a host of aftermarket products that may be able to assist you in the future. See links below...
TGC - Suspension Lift Kits, Leveling Kits, Wheels, Tires, Shocks and More!
Truck Lift Kits, Sus*****on Lift Kits, Lift Kits for Truck | Truck Toyz - Truck Toyz Store
