Fairly dumb 1997 manual transmission question
Hey guys,
I'm trying to change the fluid in my 1997 with a manual transmission. While taking out the fill plug on the side of the tranny I broke my ratchet. The sucker is in there tight. I was just wondering if maybe these things are left handed threads? Also, a 3/8 ratchet fits in there perfect (with no socket, just the square ratchet), is that how its designed or am I using the wrong tool?
I'll try to soak it in wd-40 and try to hit it with an impact wrench rather than a pry bar, but if that doesn't work is putting some heat on the bolt a terrible idea?
In other news, after all these years slamming your funny bone into the transmission is STILL not funny!
Thanks
Thanks
Hey guys,
Thanks
Thanks
That is about the right size. Sometimes you can find those square "hexi" type tools, but the ratchet works just the same. They do get corroded up in there on the outside, so the penetrating oil is the best approach! Not many people ever really service their manual trannies, which is why you are having the fun you are now! LOL!
I had the same problem. DO NOT USE air tools! I did and began to round it out. I ended up putting my ego aside ( was pissed off having to) and took it to jiffy lube. It took four trained pros taking turns 20 mins to get it out! About heating it, i cant say. Id say go for it but it is a transmission...
As for fluid, I like royal purple.. Pricy but I like to make sure all is well under there! Viscosity.. Keep it light. Too heavy and its a sonna gun to shift in the cold!
Received 3,110 Likes
on
