Getting a Bump On my 2010 Lariat
Ok I read some threads and this does not appear to be rare, only its not clear what the issue is. Most times when I start my 16K mile truck from a dead stop it feels like the ujoints are worn out or a motor mount has failed or a brake has released. I feel a clunk or a bump when I start and sometimes when I stop. I have not taken it to the dealership yet but I figured that one of you would know what it is. What is it?
pop the driveshaft off
do not pull it apart
Do pull the driveshaft so that it fully extends. Clean all the old grease off (if there is any). Repack all the splines with grease of your choice. I can't remember what the TSB calls for.
Re-install and enjoy. Been an issue since 2004. Something about the metallic plating on the splines wears off and leaves a small gap...which is the noise you hear. mechanically the driveshaft is still A-OK. Just annoying noises. Ford mostly fixed it by 2006, but occasionally guys still get the problem. Sorry to hear your 2010 is suffering
Pool Runner
2009 - 2014 F150
61
03-25-2018 03:31 PM
