92 f150 Key on engine running test
Old 12-24-2011, 07:52 PM
73'360f100's Avatar
73'360f100
73'360f100 is offline
I just did a koer test on my 92 f150 302 i got the codes from it but am not sure if they are supposed to be 2 digit codes or 3 digit codes the numbers that came up are 1124135212411352
Old 12-24-2011, 08:38 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
I'm thinking the '92 should be 2 digit codes..
Old 12-24-2011, 10:40 PM
73'360f100's Avatar
73'360f100
that was what i was thinking also but the first code is 11 which is system pass but then it gives me 6 more codes. Unless maybe I read it wrong.
Old 12-25-2011, 02:21 PM
toby tough's Avatar
toby tough
toby tough is offline
My chiltons shows there are two and three digit codes.I think you should do the KOER test again and notice where the pauses are.They separate the different codes as they come up.
Old 12-27-2011, 06:12 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
'92 was one of the inbetween years for the 2 or 3 digit code transition, but I'm thinking the 302 was still 2-digit in '92.
Keep in mind that in a KOER test, there will be an engine code first (4 flashes for an 8-cylinder engine), then a "goose code" to prompt you to give the throttle a quick stab, turn the steering wheel 1/4-1/2 a turn, touch the brake pedal and cycle the O/D switch (last two are for electronic automatic trucks only). After that, there will be a short flicker which are the fast codes used by some code readers, then it gets to the actual codes. The computer will output all codes then output them all a second time.
1992FordF150Custom
06-20-2014 07:24 AM
Treytaw
04-19-2013 06:23 AM
rwdfan
09-11-2009 04:21 PM
driver97
02-06-2009 04:41 AM
Jrock909
11-28-2004 07:07 AM
Quick Reply: 92 f150 Key on engine running test
