351w EFI performance upgrades?
Old 10-08-2016, 11:55 AM
GoinBoarding's Avatar
GoinBoarding
GoinBoarding is offline
Originally Posted by 351miller
Was using scanner to read what timing was then adjusting distributor. I think it is maf but not sure either . Truck is 97 5.8
Did you remove the SPOUT connector? 97' is likely SD, assuming it's in an f250 or f350. Is there a MAF sensor in the intake tube? Is it OBDI (EEC-IV) or OBDII (EEC-V)?
  #182
Old 10-08-2016, 12:22 PM
351miller's Avatar
351miller
351miller is offline
Assuming what the scanner was showing was volts for o2. Where do I start checking to find out why it's running rich. I would have thought with the amount airflow I added it would be lean
  #183
Old 10-08-2016, 12:45 PM
351miller's Avatar
351miller
ok what can gather from Internet and looking at truck. Obd 1 and sd no sensor in intake tubes and eec plugs is under hood drivers side inner fender.
  #184
Old 10-08-2016, 01:51 PM
351miller's Avatar
351miller
Truck is obd1 with sd
  #185
Old 10-08-2016, 04:12 PM
GoinBoarding
Which cam did you use. Sorry if I missed it. SD is sensitive to LSA.
I don't have a ton of experience I've just read a lot recently, and have been asking questions that might help one of the experts help you.
It's possible the sensor isn't working correctly. Does the exhaust smell rich? What do the plugs look like?
  #186
Old 10-08-2016, 05:53 PM
351miller's Avatar
351miller
Motor is a stock 97 5.8. Mods are pro comp gt40 heads,5.8 lower intake ported to match 5.0 upper intake, 1.7 roller rockers with longer pushrods to center on valve stems, hotter ignition from coil to plugs, shorty headers and new exhaust. Cam is factory roller.
  #187
Old 10-08-2016, 07:08 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
What kind of scanner were you using? Can it give any other information, like fuel trim?
  #188
Old 10-08-2016, 07:33 PM
351miller's Avatar
351miller
Snap on is all I can say it's the neighbor whose helping me. I'll see if he can check fuel trim
  #189
Old 10-08-2016, 07:43 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Have you located the spout?
The little grey plug.
  #190
Old 10-08-2016, 08:03 PM
351miller's Avatar
351miller
Yes played with timing today. Pulled spout out reved motor by hand and turned distributor , set it by ear but got more power and motor revs better. Feels like I'm just now back to the power I had before doing any upgrades.
  #191
Old 10-08-2016, 09:06 PM
GoinBoarding
So no timing light? Hmm. Did you check timing on the scanner with spout out?
  #192
Old 10-08-2016, 09:47 PM
351miller's Avatar
351miller
Tried bounced from 10 to 30
  #193
Old 10-09-2016, 01:16 AM
Lead Head's Avatar
Lead Head
You need a timing light to set the timing, period.
The computer has only one way to control the timing of the engine, and that is through the SPOUT wire. The computer also has no way to verify the timing - all of its timing information comes from assuming the distributor is perfectly set to 10* BTDC.
If you unplug the SPOUT connector, the computer has absolutely no control of the timing. The read out on the scanner is just what the computer is trying to command the timing to be.
  #194
Old 10-09-2016, 05:30 AM
351miller's Avatar
351miller
I'll get timing light, but do I still set to 10 Btdc with the six little tune. Also what should my plugs be gapped at. .043-.046 is stock. Running the hotter ignition should I open them up some.
  #195
Old 10-09-2016, 11:10 AM
GoinBoarding
I would start with 10 degrees and go drive it. Six liter tune up just calls for advancing the base timing as much as you can get away with, without pinging under load. I tried it with plugs at 0.055" and found 11 degrees was all my truck (96' F150) would tolerate.
Quick Reply: 351w EFI performance upgrades?
