Lengthening E-Brake
Might find what you need here: 1973-79 Full Size Truck/bronco - Brake Parts F100, F150 - Parking Brake F150 No experience with your truck, but a six inch lift may require lengthening the driveshaft. Yes, I would remove it before working. Better than dropping it on your head if it slips out.
I'm not 100% sure this will work, but I'll throw the idea out there and see what others think...
There's an outfit called Cablecraft that has dealers/distributors around the country. They can custom assemble all kinds of different cables from the components they have.
My suggestion is to have them use your outer parking brake cables "housings" (I don't know the correct term) but have the inner cores replaced with longer ones.
Just a thought...
Just a thought...
F150offroader
07-25-2008 08:37 PM
mnm99
1978 - 1996 Big Bronco
05-11-2003 12:29 AM
