NO START 6.0. WANNA CHALLENGE? LOOK HERE:(
IDK have heard a wrong oil filter cap assembly will let to much bleed off threw that oilfilter drainback and cant fill that HPO Res
Also sounds like you have the tools could put a mechanical gauge to the ICP spot and verify a good ICP sensor
Its almost has to be the HPOP if its not leaking but even at that dont the bad pumps bleed thru to the oil filter
We had the same situation at Diesel Power Challenge a couple of years ago on a 7.3. The truck had dual HPOP's (Ford) and wouldn't start without ether. Had some of the BEST 7.3 minds in the country working on it and couldn't figure it out. Finally came down to a bad "new" HPOP so we went to the local Ford dealership and got another "new" HPOP. Truck still wouldn't start without ether. Turns out that pump was bad also. I'm betting on a bad "new" pump.
I wasn't trying to be critical when I posted such a brief question - just been very busy.
I asked the question because of the lack of specifics in the original post - like what was the air pressure used during the test, did it hold pressure or was it just that no leak was heard, etc.
Sounds like you have done your "due diligence" and (as others have said) a new pump is the next step. Please keep us informed!
On my snap on modis scanner,it wont let me access vehicle security. Keep in mind i swapped comps and still no start. I put the comp in question on a running 6.0 and she started. So no prob with the comp. Were is the vehicle security on the 6.0?
#30
Yes sir chezit. I was hopeing u would chime in. Ive googled a few things about these trucks and your name comes up often. I do value your opinion,one tech to another..
UPDATE. building hpop psi now and she will run....for 10 or 20 seconds.then die.. yes,i have base oil psi. First thing i checked.
