F-250 rear end seals
Hey all
I'm ordering and hopefully installing seals on my 94 F250 tomorrow. I was wondering if anyone had some tips or tricks or could tell me if I should order anything special? What should I expect to deal with after the shafts come out? Just wanna make sure there's no secret I'm gonna miss and end up doing it again in a few days or worse.
Thanks for the help!
Red, do you know for sure the bearings arent going bad. Usually when a wheel seal leaks they are being reamed out by the bearring being out of tolerance. I would do some investigating when I got it apart. Also remember to check the seals surfaces for galding and or scoring. I wont do you any good to put a new seal on a marred up seal surface.
It turned out that the piece of the brake assembly that turns the star on the auto-adjusters came loose but was still hanging by the cable. It got wrapped up and actually wore the seal itself into two separate pieces. It also wore on the face of the hub, but not where it contacts the seal, so its no problem. I got the new seals in and haven't had any problems. It did take chipping a small piece of the retainer off to determine that the driver's side threads are left handed. Donor truck strikes again.
RipRoaringGalaxie
05-10-2008 02:05 PM
F-150Guy
06-07-2005 07:23 PM
Rancho*Ryda
06-02-2005 01:46 AM
