Im replacing my rear ProComp add-a-leaf and double block 6" set up. Ive got the 22410s in front. Now installing the 22415s in rear with a single 2 or 3" block. Is anyone running this set up and are you using a tapered or flat block?
Pro Comp says its there 6 inch spring for the front and the rear spring is a 5 inch I think and then I have the Pro Comp 2.5 inch tapered block. I guess if it start to sag Ill swap out to a 3
I'm running a similar setup, 22410 fronts, and 25492 rears. I have pics in my gallery here: Phyrmn Gallery. It's a rougher ride than stock by quite a bit, but tolerable.
its been almost 45 days since they were installed, no noticeable sag yet. Im happy with the firmer ride, but the ride really isnt too bad but since this is mainly used for the highway I switched to the 305/70-18 Dura Grapplers which soak up some of the bumps.
