Gas tank paint
Gas tank paint
Hello. I have just completed the install of a Jeep Commanche gas tank in my 48 F1. Before I put the box on I would like to paint it. It is a new tank and is a silver coloured plating,any ideas on what to prime it with?
The filler will be through the left rear fender with a 47/48 passenger fuel door.
painting your gas tank
The plating is zinc, same type used on shiny bolts and many other steel products. If you want a do it yourself paint job you can't go wrong with the previous post. You can go 1st class with a body shop applied etching primer and
polyurethane top coat (any color). The polyurethane is a 2 component (base+curing solution) really good quality paint.
lodogg89
03-01-2012 09:22 PM
65f100pdx
07-03-2008 07:27 PM
taylor0987
05-16-2005 11:48 AM
