topper opinions needed
Old 12-12-2011, 04:43 PM
Scott Stewart's Avatar
Scott Stewart
Scott Stewart is offline
I have this topper for my truck - I got it used at a good price (50.00 bucks) and I want to know the best way to mount it - right now i have four C clamps securing it. However i found four bolt holes on each side in which the former owner drilled into the bed rails to mount it. I'm not sure if clamps will hold it or do I NEED to drill and bolt it down? What's you opinion?
Old 12-12-2011, 04:55 PM
bashby's Avatar
bashby
bashby is offline
I think c clamps will hold it on fine and will be easier to get off if you need to remove the cap. lube the threads up so they dont rust.
Old 12-12-2011, 04:57 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
If you don't want to drill your truck full of holes, they make a clamp just for camper shells that work much better than c-clamps. You should be able to find them at an RV place for sure, they may even be available at some parts stores.. I think they come in a set of 4 but if I were going to use them I would rather have 3 on a side (I have been accused of going overboard on things though), that looks to be a fairly heavy camper shell.
Old 12-12-2011, 05:48 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
What White 97 xlt said
Also if you decide to bolt it down, use eye bolts. It will give you more spots to tie things down
Old 12-12-2011, 05:49 PM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
I would go to your local store that would sell these things and get the clamps that are designed for mounting toppers, I have a place near by that installs them when you buy one, so im not sure if they would sell them just by them selves, I would guess they do...
Old 12-12-2011, 06:37 PM
DIYiT's Avatar
DIYiT
DIYiT is offline
I'd find a set of topper clamps. They're better than the C clamps and you don't need to drill any holes to bolt it down.
Old 12-12-2011, 06:38 PM
blkF250HD's Avatar
blkF250HD
blkF250HD is offline
Get the clamps. Also make sure the seal on the bottom of the topper is good and there's rubber or something to go between the bed rails and the topper. If there isn't the vibration will scratch the hell out of the paint. 3 clamps per side should be fine.
Old 12-12-2011, 07:44 PM
frederic's Avatar
frederic
frederic is offline
While I don't have a topper on my current truck, on my old Dodge I did something clever. I welded together a big "U" out of angle iron and placed it on top of the bedsides and front, then put my topper on that, bolting through the topper, the angle iron, and the bed sides.
Then, to the angle iron, I bolted on quite a few "D" rings down both lengths... it was great for tying things down - tool boxes, engines and other larger car parts, and so on.
Old 12-13-2011, 01:13 AM
tbirdscott's Avatar
tbirdscott
tbirdscott is offline
Four C-clamps will be fine unless you rally your truck on the weekends. Put some foam tape on the bottom of the canopy to protect your paint and keep rain/snow out.
Six clamps isnt a bad idea but 4 will do. The special canopy clamps are cheap and usually come in just a 4 pack.
Scott
Old 12-13-2011, 09:30 PM
toby tough's Avatar
toby tough
toby tough is offline
One of mine has a ladder rack on it so I bolted that one down. But my noisy in the rain aluminum one has the topper clamps.They work great.
Old 12-13-2011, 10:29 PM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
All our service toppers on our 09 f150s at work are just held down with the clamps can't remember if there's 4 or 6 tho
jerry_s
15
03-12-2018 09:27 PM
joegeds
07-12-2013 07:25 AM
ExtrmZ
Appearance & Dress-Up
01-25-2010 06:25 PM
Danny_Ocean
Garage & Workshop
45
07-19-2007 11:20 PM
jmw00
2004 - 2008 F150
11-07-2004 10:25 AM
Quick Reply: topper opinions needed
