Bell housing patterns . . . 351C & 302
Will a '77 302 and a 351C mate up to the same FMX transmission? . . . not at the same time of course.
Running the 351C / FMX now. I've got a good '77 302 I'd like to run in front of the FMX while I decide what to do with the 351C.
Is this a straight forward swap?
Mitch
Mitch
Thanks guys. I've had the 351C and fmx in my old truck for several years. I quit driving it bad in '99 when the tired old 351 wouldn't hold good oil pressure. As best I remember, the fmx leaked, but worked well when I quit driving it.
I'm trying to get the old pick up running again with out sinking a lot of money into it. I just bought a good 302 and C4 to put in the truck. Found this setup at a price I couldn't pass up.
Trying to decide whether to include the C4 in the swap, or just swap the engines and try the fmx.
Mitch
Mitch
It's pretty easy to change a driveshaft, but it's a lot more work to separate both tranny's, bolt the FMX up to the 302, install it, find out it doesn't work, and then either drop it and rebuild it or put the C4 in there and have to deal with driveshaft lengths anyway.
On the other side, putting a C4 where an FMX once was can create problems too. TV cable (if a C4 has such a thing), vacuum lines, shifter linkages, tranny mounts, etc. are all potential gotchas.
Just some food for thought. Good luck with whichever approach you take.
Mitch
Mitch
mgoovaerts
10-19-2005 12:15 AM
mgoovaerts
10-18-2005 08:17 PM
fordman042
10-29-2002 12:30 PM
