99 f250 low range light stays on
Old 12-11-2011, 05:03 PM
ahoop90's Avatar
ahoop90
ahoop90 is offline
Both the low range and 4x4 light won't go off in my 99 f250 4x4. Its manual shift 4x4 and i know its in 2wd. The transmission shifts through all gears and is in overdrive by the time i hit 30. It seems like its shifting like the truck is in low range still. Is it possible that the truck thinks its still in low range even though its not?
Old 12-11-2011, 05:14 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
With a fault present the PCM can still get the signal the trans is in 4L.
This signal changes the shift program.
Old 12-11-2011, 07:29 PM
ahoop90's Avatar
ahoop90
ahoop90 is offline
Thanks for the reply, any ideas on where to start on finding out whats happening? I'm gonna check fuses and relays first, but any other input would be greatly appreciated.
Old 12-11-2011, 09:26 PM
Bluegrass 7
First thing is to check out the shift linkage to see if the positions are correct.
Put it in 2wd and look at the hardware, then in 4H and look again then 4L look again.
The positions send the signals to the PCM on what to do and engage the tranfer case and front actuator.
The actuator that shifts the transfer case internal power flow to 4L also signals the computer via a dedicated line to change program control..
Unless you go over all this, it can't be guessed at unless your lucky..
Good luck.
Jeff Meyer
01-01-2018 09:50 AM
trevorrules
07-18-2015 05:10 PM
rodneyp10
02-11-2014 06:34 AM
expy37at
1997-2006 Expedition & Navigator
11-05-2008 03:50 PM
Dean
1999 to 2016 Super Duty
10-13-1999 08:08 PM
Quick Reply: 99 f250 low range light stays on
