87 Bronco II no power to fuel pump
Not getting gas to the engine. Checked power to fuel pump. No power. Traced back up and found a connector with one red wire coming in and the 2 wires to fuel pump coming out. Getting power through the red wire and the male connector coming from the red wire, but power is not going through to the 2 wires going to the fuel pump (the inertia switch is working fine). Can I bypass this connector to see if fuel pump is working, also, what do I ask for at the parts store?
Maverick1978
Bronco II
12-23-2011 08:32 PM
