Replacing Front Seats - 96 f-250
2 use the search function
3 you dont have a 60-40. You could have one of 3 choices. A 40-20-40, split bench, or buckets
Drilling holes for seat brackets??? Safe???
[QUOTE=Diesel_Brad;11140766]1 welcome to the site
Hi Diesel_Brad
I've searched but so far not finding what I'm looking for. Hopefully u might know. I have found a sweet deal on some captain's buckets from a 2003 Expedition. If the seat brackets on the buckets don't match up to my F250 holes, can I just drill new holes and mount the buckets?
I've never added different seats to a rig and don't know if just drilling new holes for the bolts and nuts would be safe.
Any thoughts?
Hi Diesel_Brad
Any thoughts?
[quote=f_250;11157025]
I'll help you out here. I just put in bucket seats from a 93 Probe into my F250. If the holes dont line up, then drill appropriate sized holes through your floor and make sure that your seats line up the way you would like. Then tack weld a washer on the underside of the truck to increase support, because if you hit something you wouldn't want your seat to rip out of the floor. Then put a bolt and nut through, tighten them down, and make sure your seatbelt ends up where you want it. Thats about all there is too it. Oh and i suppose if you really wanted to make it easier on yourself, you could weld the nut to the washer so you dont have to have someone hold a wrench on the nut when you tighten.
Hi Diesel_Brad
Any thoughts?
Hi Diesel_Brad
Any thoughts?
[quote=mreid99;11161685]I dont have any before pictures, i might be able to take some pictures tomorrow here if I remember or can locate my camera. Im not really liking the probe seats because i hadnt taken into account the lack of arm rest which is kind of uncomfortable. So i might have to find something to use as an armrest or find some other seats.
An update about my seat replacement project: I took a close look at my 40/20/40 front seats in my 96 f250 extended cab and discovered the job will be more difficult than I figured. The floor of the truck has quite a hump where it passes over the tail of the transmission, etc. Ford has mounted the seats on a clever assortment of shaped metal supports that follows the contours of the cab floor and creates a flat platform for the seat tracks. It means I can't simply bolt on new seats to the floor. That narrows down the availability of seats. I've heard that seats from late 80s to 99 f150, 250, 350 extended cab will work. So I continue the hunt!
jacew
01-01-2007 09:19 PM
CHACH
11-19-2003 07:38 PM
