Help with Upfitter switch fuses???
Old 10-25-2014, 10:48 PM
jim48's Avatar
jim48
jim48 is offline
Yeah I'm sorry too guys. It was a little problem three years ago, something simple I just don't remember. No games being played on my part, and I hope no one(well maybe one person) thought otherwise. I guess I could have said it was a ground issue, fuse, loose wire but after three years I simply don't recall. I should have never responded to such an old thread, lesson learned..........
Jim
Old 10-25-2014, 11:34 PM
Brandon D's Avatar
Brandon D
Brandon D is offline
Lead Foot User
Originally Posted by E077528
Just a newbe mistake. I will try to be more careful going forward.
No worries, you never made a mistake at all.
Jim
Don't apologize. I think things got misread and I hope 69cj was misunderstood or maybe having a bad day? Glad you got your issue sorted and I understand that you're not playing games. Cheers
Old 10-26-2014, 08:32 AM
69cj's Avatar
69cj
69cj is offline
Actually it didn't come out the way I meant it. Should have learned long ago to re-read before hitting enter. Was just disappointed not knowing what the outcome was.
Old 11-01-2014, 11:07 AM
sgrol's Avatar
sgrol
sgrol is offline
Darn, having same problem. Lights on upfitter switches comes on but no power output. I thought it was just my #3 switch which controls my Light bar but #1 (high idle) doesn't work either. FWIW - when fuse #44 was pulled the upfitter indicator lights on the switches went out.
Old 11-09-2014, 10:57 PM
rray32539's Avatar
rray32539
rray32539 is offline
There are also fuses in the upfitter switch module that installs on the driver side of the instrument panel near the parking brake. The fuse for the upfitter switch module on the passenger side is for the entire module, not for the individual circuits. Chances are you have a blown fuse at the upfitter switch module itself.
Old 11-10-2014, 07:26 AM
sgrol's Avatar
sgrol
sgrol is offline
I believe you are referring to the relays. I have checked them and can only confirm that they are clicking when switches are energized.
Old 11-10-2014, 07:54 AM
MPD56's Avatar
MPD56
MPD56 is offline
I believe that F44 is for the control power to the switches, which energises the relays. F9 is the power fuse for the #3 Switch.
Old 11-10-2014, 07:58 AM
sgrol's Avatar
sgrol
sgrol is offline
All checked and OK.
Old 11-10-2014, 08:51 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
All checked and OK.
you were going to check the other two unused UF wires to see if all 4 were dead, which could give us another clue.
Old 11-10-2014, 09:21 AM
sgrol's Avatar
sgrol
sgrol is offline
true havent got around to it yet
Old 02-26-2015, 05:18 PM
Forrestt137's Avatar
Forrestt137
Forrestt137 is offline
I was wiring up some lights form my aux 3 and I hit the hot wire on the frame and have lost all power to that wire. My aux 1,2,&4 still work but not 3 what fuse is going to go to that upfitter
Old 02-26-2015, 05:23 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
says fuse #9 in the fuse panel in the front passenger footwell, behind that plastic panel.
I assume the UF switch light still lights.
  #28
Old 02-26-2015, 06:01 PM
sgrol's Avatar
sgrol
sgrol is offline
Haven't done any other troubleshooting but all switches seem to be working now. Go figure.
  #29
Old 02-26-2015, 06:06 PM
Forrestt137
I can't seem to find the fuse panel on the passenger side
  #30
Old 02-26-2015, 06:12 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
inside the vehicle, on the passenger side, under the dash, on the right side, remove the panel between the door edge and the floor
rmh1999
06-02-2023 11:40 PM
Flench327
Electrical Systems/Wiring
28
06-02-2016 07:34 PM
Dr. Monstaa
38
10-21-2012 09:23 AM
99EdeBauer
1997-2006 Expedition & Navigator
08-03-2011 04:24 PM
Padre
10-17-2007 06:58 AM
Quick Reply: Help with Upfitter switch fuses???
