"Grind Me A Pound" with a ZF5??
My ZF5 likes to grind into reverse. Typically it happens when I'm trying to back into a parking spot. I'll come to a stop, press the clutch, shift to neutral, hold the clutch for a second or so, then try to shift into reverse. Probably close to half the time, it grinds. I end up having to release the clutch, and press it again. Then it normally works.
What's going on? Is that normal? Most other manuals I've driven, I can shift into reverse when I'm still rolling to a stop.
And good Lord is it embarrassing in a parking lot full of people
My truck does the same thing m. I'm not sure if this will work with zf5s but whenever he goes into reverse he shifts up into 5th gear then down to reverse. I haven't been able to try it as my transmission isn't in my truck yet I was hoping a good clutch and slave cylinder would limit the grinding
Received 3,114 Likes
on
You may think it's going in reverse, but the trans may be "confused"...........................noise is very common for the ZF5, but some options:
(1) Clutch adjustment is off or the rod is worn (check under dash)
(2) The reverse lockout tab might be mis-aligned, even missing (happens frequently when the cover is pulled)
(3) "Over-fill" fluid via the shifter during maintenance (this also seems to help with the neutral "chatter" issue common to the ZF5)
Well, I had to get a u-joint replaced before I could test it.
I tried shifting directly from second to reverse, it started grinding on me. Shifting from fifth straight down was a no go, it wouldn't drop into reverse until I moved it back into neutral between 3 & 4.
I don't remember if I left it in gear until I came to a stop or not. I'll have to try again and make sure I do that.
