Crossover steering on 4'' lift?
Stock steering will be fine however you will need a dropped pitman arm. The 250 with a 4" lift drives really nice you will be happy!!! A steering stabilizer that mounts to the engine xmeber to tire rod will be a added plus as well. Good luck!
ok great info thankyou
Ford Suspension Lift Kit
i was looking at this rough country lift and its the cheapest one i could find.
do you think it would serve me well??
Works and correct are two different things.
Take the truck pictured for example it "works" as configure yea but its not correct, the linkage should be parallel to axle/ground.
While the drop pitman arm on it does correct for part of it its not enough in of itself for the amount of lift, the "toe" setting changes constantly as the trunk encounters dips/rises and bumps in the road and when loaded/unloaded.
Not to be confused with similar condition "bump steer" though as driver isn't likely to have to constantly make steering corrections as it encounters those same dips/rises in the road/trail, least not to any great extent.
Not a big issue off road but surely reduces tire tread life because of it, a big issue when consider cost of those type/size tires.
Lifting the truck 4" or 2" is all the same just a taller bracket. You cant just change the springs without lowering the inner pivots. Ive had the 4" with 35's on for over 20 years getting even tireware. I just switched to all terrains because the muds were no longer avail but the muds were getting me in the 30,000 mile range. The steering linkage is at no sharper angle now than when brand new. I guess im just happy with my incorrect set up
