I am changing my truck over from a 3 speed manual to an automatic. how can i tell which flywheel i need to get. i have heard that if its not the right weight it will make everything unbalanced. any ideas ????? I'm going to be running a 302 with a c6
But is it a 302? 1978 Lincoln Versailles was also available with a 351W. The flywheels are not the same.
Is the difference the diameter/tooth count? If so, using the C6 trans he will very likely need the larger, 164 tooth flexplate, no matter if he's got a 302 or a 351. The bolt pattern is the same. It would be good to know the application the trans is from, as that may have a bearing on which flexplate is needed, too.
On a side note, the C6 would not be my choice with a 302, way too much hp/torque loss for that small of an engine, but that's another post for another time. ;-)
