X Code Question
X Code Question
I am replacing my worn out V code springs with new Ford X code springs this afternoon. My question is, and believe me I have searched and researched this forum for the answer, should I install an adjustable track bar with the swap? An alignment is a given, but will the change be significant enough to warrant a new track bar?
I haven't forgotten you, CC turbo. I'm in the middle of it now and I will measure for you at the end of the project. I referenced from the bottom of the fender to the center of the hub for my information, but I can measure both ways if it will help. I hope this fixes that god awful spring squeak as well.
Later.
Later.
Later.
Later.
Let us know if you feel a difference with the X codes. I didn't really feel any difference.
That "god awful spring squeak" was probably from worn spring tip isolators.
Do the new X codes have spring tip isolators? TSB 99-16-3 New Part #1C3Z-5B302-AA TSB was for 99 models but holds true for later years.
Pics by high ho silver
Yes, the new springs do have the isolators.
CC Turbo...I was able to measure from the top of the spring block to the bottom of the frame. It is 5.5 inches. Doesn't seem like much after having so many lifted trucks in the past.
I was able to gain about 1.25 inches of height. I was hoping for a little more, but it is what it is.
The odd thing is that it is about .75 inch off from side to side. The drivers side being lower by .75 inch. It was the same difference before the change.
Anyway thanks for the help, and I hope the measurements are what you are looking for.
Are these the right ones for my 99 F450 it has a nasty squeak, i know it needs new swaybar parts I was changing the oil the other day and looked at the front spring ends and pushed on a piece that was sticking out of the bottom of the spring near the end and the center of one of the isolators fell out.
