Heater stuck on floor/deforst
I just noticed that my front heat is stuck on floor/defrost. I change it to dash vent, and very little comes out and most of the air is coming out of the floor/defrost. Vacuum line?? Door flapper stuck?? Switch??
Where should I start looking? Not sure where the door flapper would even be located at and even how to get to it. Can I test my switch selector?
Thanks in advance for your help!!
Do your other blend doors (temperature; rear system) work in the system? If it's just the one that died, it'll probably be just that door. If it's all the doors, then it's probably vacuum.
I seem to remember reading something about when vacuum is lost it goes to defrost, but I thought it was full defrost, not floor & defrost. I've not dug into this system yet fortunately, I just remember reading that before I did the front hub job.
Yes, the temp adjust works, I believe the rear works as well, but I need to go out and verify.
Any idea where and how to find that blend door??
This link may help you out to see where it is located.
| Repair Guides | Air Mix/mode Actuator (blend Door) | Removal & Installation | AutoZone.com
ALedbetter1
10-17-2014 09:41 AM
bkcanada
10-15-2007 01:47 PM
bartamos
04-21-2006 11:50 AM
