05-F150 Passenger Footwell Cold Air
My 05 Lariat has cold air coming into the passenger footwell from up under the dash. Wife alerted me to this but didn't really listen until a buddy mentioned it while we were driving in minus 30 celsius weather with full heat on. Can't seem to get it to stop. Doesn't matter if heating system is on or off. Anyone had this issue? Starting to get cold here again and we've got a few long distance trips planned.
If the driver window is cracked open, the passenger's feet may get cold. That's the way the air flows. I'd bet that this is your problem. Are you a smoker? Smokers leave the window cracked open.
A bright light will be the best way to find any air leaks. Even if you can't see the hole, you may still see the light shining through. Have someone shine it from inside the passenger compartment, and the engine compartment. Have them move the light around at different angles.
If light and air can get through, so will water.
You had better take off the panel covering the fusebox and shine a flashlight down in there, looking for water. This is where it accumulates if the windshield is leaking.
JesterPgh
04-14-2009 07:06 PM
