Quick I Beam Question 92 F150 to 85 F150
I am doing a frame swap on my 92 2wd LWB f150 due to passenger side frame horn damage, and going from long box to Flareside short box. I found an 85 f150 SWB 2wd frame and want to know if the I beams and radius arms will bolt up. I know the I beams were changed at some point in time, but I do not know if it was between 85 and 92. I did a search and nothing came up, so I looked at the bronco graveyard site, and sure enough, the axle pivot bushings are different. I do not know if the difference in bushing will affect the mounting of the I beam.
Any help on this matter is appreciated.
I don't know for sure however would think few minutes with a tape measure would answer your question fairly quick.
I could see maybe a difference in radius arm length LWB to short box, maybe tad longer on the LWB perhaps? however can't think of any good reason why the I beams be any different "length" wise.
Take a few key measurements of yours, compare when you get there.
Rick Schmidt
03-30-2014 01:23 PM
cujo8
20
12-19-2006 12:16 PM
TexasGuy001
02-17-2002 01:01 PM
