SAS Dana 44 vs Dana 60
I'm looking to do a SAS on my '87 F-150. I am wondering are the Dana 60 worth the added durability or are the Dana 44's good enough. i don't do any serious wheeling the most i do is go up on the mountain to get some firewood. I've looked high and low for the Dana 60's and not found any. at the local junkyard they just got in a 78 f-150 and i can pick up the set of axles there for $400. Where as the Dana 60 set will run about three times that. Thoughts?
Good luck to any replies. I think the 44 will work just fine. If you want you can upgrade your axles to chrome moly with spicer ujoints. Chech out Wildhorse 4x4 at WILD HORSES 4X4 Off-Road Parts and Accessories 66-79 Ford Broncos. Talk with Johnny he will take care of you.
If you plan on keeping the rig and using it, I would go with 60's. By the time you buy the weaker F150 44, plus all the upgrades and everything needed, you would probably have nearly a set of 60's paid for and still be way stronger. An added plus is that you can walk in to most any local parts store and get parts for the 60 and not have to wait for custom moly parts or expensive aftermarket to be sent. The rear 60 is no problem and they are laying around pretty much all over. So you just need to find a front 60 in the ratio you want. Where about are you located? I have a set of Dana 60's with 4:10 ratio in them I am planning to sell. I will tell you waht, if you buy the front diff I will throw in the rear 60 as part of the package. Let me know if you are still looking for a set of 60's or you decided to go with the 44 instead.
if you can get a 60 front for a decent price i would but if not for the type of wheeling you say your going to do a 44 would be fine. i dont know what size tire your going to run but a 44 will hold up to 38s just to get firewood. i had 35s on my 83 with a sas d44 and a built 351w and beat the **** out of it.
A 44 would be just fine, a 60 would just be wasting money. Plus you wouldn't have to change the rear axle simply because of lug patterns. Honestly, for just getting firewood an sas swap isn't necessary. The TTB isn't as weak as many will make you believe. But if your dead set on an sas, go with the 44.
I agree with aic the ttb front is pretty stout. i went with a sas because i got tired of fighting alighnment issues every few months. i also broke the long side slip axle a few times. another thing to think about is a 44 swap is straightforward but a 60 swap youll have to go to leafsprings in the front or convert the 60 to coilsprings.
KcinMI
01-31-2005 07:36 PM
lilpig88
09-18-2004 06:53 PM
Dirt Head
06-27-2003 11:25 PM
ford_nut
07-13-2002 07:55 PM
