'96 door handle pull, key unlock and button unlock problems...
I did a search and didn't find answers for our OBS trucks...
Three different problems on three different doors on my 'new to me' 1996 crew cab. Might as well solve all of them on all four!
Problem #1: The front driver's inside door handle just started to pull hard. It's the first little bit of upward pull that is hard, then it moves through the rest of the movement normal. The handle doesn't seem to need to be pulled any farther than before to get the door to open. Just this recent sticky/hard start of the pull.
Problem #2: My passenger's side front door is difficult to unlock with the key. The lock seems to unlock fine with the remote fob and the buttons. It lifts smoothly when pulling the manual post.
Problem #3: The passenger's rear door lock does not pop up completely. It lifts smoothly when pulling the manual post. The electric lock needs to be bumped a couple of times (either by the button or the remote fob) to get the manual post to raise enough for the door to be opened.
Thanks for any and all suggestions and links to other people's solutions!!
