Death Wobble / Shimmy Has Arrived!
So over the last 1000 miles, the front end death wobble has arrived.
The wobble (steering wheel shaking violently), shows up inconsistently at 59-60 mph, and doesn't go away until I hit the breaks. Only at that speed thought, and I can't reproduce it on the same road....
So...
1.) Why all of a son in the last 1000 miles, cooler temperatures? Affecting crappy shock rebound rate?
2.) Why is it not reproducable on the same road all the time?
I can't even bring it to the dealer and complain really, because I can't get the truck to do it all the time.....I do notice it's always on bumpier sections of the road, and I got the WTH was that look from the wife the other day.
Am I wasting my time by bringing a Tech for a ride and hoping it goes into the violent wobble, or should I just upgrade the shocks and hope it goes away, or is it worth complaining at the dealership?
So...
I know what you mean. I had it happen and it was seemingly random too. It went away when I got new shocks and tires, so I can't make it happen at all.
What's worse, I don't know what cured it, new tires or shocks. I am betting that both helped. Are your tires close to the wear indicators? I dunno, probably the shocks more than anything.
You could complain and have your alignment/track/caster checked for free.....Maybe get a wheel balance out of it too.
Check out THIS THREAD.
I do not agree with spending money on aftermarket shocks to correct a defect. While shocks can help with the situation they certainly do not cause this; the root cause is your axle moving more than it should. The likely solution is a new track bar.
Take it to the dealer, I believe there is a TSB for this. Don't hide the problem with shocks, get it fixed!
This is one older article from Peterson's 4-Wheel and Off-Road.
Ford Super Duty Death Wobble Cure - 4-Wheel & Off-Road Magazine
Here is some reading: (geared towards Jeeps but also mentions Ford trucks)
How To Fix Your Own Death Wobble
in Death Wobble Cures
retweet
(If you have questions or a comment… post it below, and we’ll answer you ASAP!)
As you have already found out, “Death Wobble” is the horrible front end vibration that starts when one tire (usually the right tire first) hits a groove or bump in the pavement somewhere around 40~50mph. Death Wobble is quite possibly the worst possible downside to having a coil-sprung front suspension on a vehicle with a track bar or panhard bar. Vehicles affected by this design are the Jeep Cherokee XJ, the Jeep Grand Cherokee ZJ and WJ, TJ and JK Jeep Wrangler, (and also include trucks like Toyota, Ford, and Dodge Ram, as well as early Ford Broncos). Death Wobble is also extremely difficult to try to diagnose and fix, because it is actually caused by slop in the entire steering system as a whole, not by one component. To diagnose and fix Death Wobble correctly, your mechanic needs to look for “play” everywhere in the steering and front suspension system, searching for anything that could have “play” in it. It’s very time consuming to find a Death Wobble fix, and can be downright dangerous while you are in “testing phase”, trying to exorcise this demon from your Jeep or Truck.
The place I tell people to start, is with an overall visual inspection. Spend 10 solid minutes under the front end, visually inspecting each one of the steering components for shiny spots on steel, rubber, or polyeurthane, which is typically indicative of suspension components that are moving around when they are not supposed to be. Pay CAREFUL attention to the track bar (also called a Panhard Bar inside and ouside the USA, as well as variant spellings (misspellings?) of trackbar, tracbar, and trak-bar ). The Track Bar is often the culprit in many cases. And, if any of your bolts are even the least bit loose, Death Wobble also can manifest itself and make your life a living hell, so check for looseness everywhere.
If everything appears to be “normal” on the underside of your Jeep or Truck, and you’ve verified the bolt tightness on both ends of the track bar, the next thing to do is to start with a front end alignment, making sure that caster (frequently misspelled as ” castor “) is set correctly as well as toe-in. If you have been offroading and have bent your tie rod even slightly, that, also, will throw off your alignment. Plus, it’s only $40 or so at your local alignment shop. By the way, DO NOT let the alignment shop talk you into a four-wheel alignment, as this is only useful on vehicles with independent rear suspension in my experience, and since there are no adjustment points in the rear of a live-axle vehicle ANYWAY, you’re merely paying for a service that you won’t get by the time you leave the alignment shop. Furthermore, if you have a lifted vehicle, make sure that the alignment shop you choose knows the variant specifications for lifted vehicles, and that they do NOT set it to the “default/stock” settings. A good quality alignment shop familiar with lifted 4×4 vehicles will know these settings, and a poor quality shop will likely tell you that it doesn’t matter whether it’s lifted or not…and that they use the stock specs. Walk away immediately, or hang up the phone and call the next shop, if they do.
If you are now *certain* that the front end alignment that it’s set correctly, and that you have not replaced ANY other front end components recently (including tires or wheels) that may have caused the oscillation to begin, I tell people the next most suspect thing is the factory front track bar. Over time, the tie rod end on the upper portion of the Panhard or track bar (some applications like the WJ Grand Cherokee, the Ford Truck and the Dodge Ram have a rubber bushing configuration instead, which also wears out) develops “play” in it due to wear and miles on the vehicle. The same findings often goes for the lower end bushing, which has a rubber or polyurethane isolator bushing in it, and this “slop” will allow the Dreaded Death Wobble oscillation to occur.
Aftermarket trackbars generally come with urethane bushings that allow a LOT less “play” (with respect to movement / crush) than the factory rubber bushings do. The problem with most aftermarket track bars for the Jeep is that they also come with either a Heim joint, Johnny Joint, or tie rod end on the upper end of the Track Bar, which works fine for a while, but wears out over time, leaving you right back where you started, with a large mess in your shorts, a temporarily deafened right ear (from the wife screaming for dear life, or, quite possibly at YOU, for buying the Jeep to begin with, lol), and an overall high level of frustration with your entire rig in general…which doesn’t often lead into a smooth, stress-free trip.
The reason why I created my Track Bar Conversion for XJ Cherokees and ZJ Grand Cherokees is to eliminate that problematic (and expensive to have to replace when it wears out) previously mentioned joint, as well as for the additional flex benefits you get out of it. If you are running an Cherokee XJ or Grand Cherokee ZJ with or without Death Wobble, and it has more than 1.5″ of lift, I highly recommend you check it out. A complementary product we have found to work VERY well in getting rid of Death Wobble is our exclusive Hard-KOR brand SuperDurometer Track Bar Bushings, which are also available for the Track Bar Conversion. They are about TWO TIMES as hard as the typical polyurethane bushings that come in most aftermarket track bars, which typically are made by Daystar or Energy Suspension for most of the various aftermarket manufacturers. Polyurethane bushings are also one of the least expensive replacement parts in the steering components, so they make sense to try first.
Many aftermarket track bars as well as the stock track bar are completely ineffective in managing Death Wobble due to their “effective angle of operation” particularly if you are above say 2 or 3 inches of lift. Keep the thought in the back of your mind, that another alignment is necessary after replacing ANY front end components, especially if Death Wobble still remains. Sometimes you might get lucky and don’t need one…but be forewarned.
The next thing to check is your steering stabilizer. I recommend AT THE MINIMUM, replacing the stabilizer (or dampener, as it’s sometimes called) at the same time as whatever worn components that you find under the front end, as this
“combination punch” is very often more effective than the change caused by each of the parts alone. Death Wobble shakes EVERYTHING, and loosens up OTHER components at the same time. I’ve found that replacing the stabilizer by itself often times doesn’t eliminate death wobble directly, but that it often helps with some other poor handling characteristics, which cause the onset of Death Wobble (such as wandering, for instance) and a new one seems to tighten up the entire steering system. I ONLY recommend our Hard-KOR Steering Stabilizer or the OME SD40 stabilizer , because either one seems to be tighter and work better for stopping Death Wobble than the other manufacturers of steering dampeners and stabilizers on the market (and I’ve tried them all, trying like hell to get rid of a WJ Death Wobble problem years ago). They are also the most heavy duty that I’m aware of. These two stabilizers are the ONLY two that I recommend to ANYONE who is having trouble with Death Wobble, and it’s also one of the least expensive parts to replace in your steering system to attempt to remedy the problem.
Here are some other steering components to check over for looseness or improper movement:
Another source of Death Wobble is over-inflated tires (you should have somewhere around 30psi or so in stock sized tires, and far less pressure the larger your tires are. See Boyle’s Law and consider how much more volume of air is inside your 33″ tires compared to stock-sized tires. As an example, I run around 18psi in my 37″ tires).
The last thing that I can mention that has caused Death Wobble in the past is hub bearings. If there is a little slop in them over the years and miles, they MAY indeed help to cause the oscillation as well. I mentioned them last because they are the most expensive to replace, and probably least likely to be the ROOT of the problem (though they might be a component adding to the problem).
While you have the front end apart, you should consider adding some offset upper ball joints to your Jeep if you’re running a lift kit, in order to return the caster back to what a stock Jeep would be if you are running say 4″ of lift or more. Be aware that on 4×4 models (especially full-time 4×4 models), by NOT changing the ball joints to the offset type, you add more vibration to the front drive shaft since you are also turning your pinion angle downward in conjunction with every caster angle increase. In other words, you can’t have one without the other, and on the full-time 4×4 models, you’ll get a little vibration at highway speeds by NOT doing so. Compared to Dreaded Death Wobble, however, this is a VERY small price to pay, lol.
Hopefully this short checklist gets you started on the right foot and helps to cure your Death Wobble problems, and gives you a permanent Death Wobble Fix.
retweet
- Tie Rod Ends (all four, plus the upper track bar end)
- Upper and Lower Ball Joints
- Track Bar Mounting Bracket Bolts
- Steering Box Bolts
- Track Bar Ends
Alright...I'm gonna bring it in and tell them what's going on. I am running a set of BFGs off my old truck...but they still have about 30% tread left. I have no other modifications to my suspension, with the exception of air bags in back. No mods in the front.
I 'll have them put it up and see whats going on. I've pulled on the front tires to make sure I don't have a lug nut that sprang loose on me, and found nothing...won't be able to get it in this week, so I'll make an appointment for the following week.
OK...wobble horrible today on a stretch of road, any speed between 58-61 mph was scary...was able to stay out of it by going faster or slower. Only problem is, this section of road is about 40 miles from my dealership. Seems like the condition of the road has to do alot with if the truck goes into "wobble mode"...
I was just thinking, I think it's worst since I pulled by toolbox out of the back of the truck. Getting it in this week, wife's afraid that it'll go into the wobble state while she's driving it...
Good Idea, i'm gonna see if it threw a weight or something. Wouldn't I feel it get progressively worst with speed if that's the case??
Thanks
Thanks
Mine had/has the wobble. Took it to the dealership at 11,8XX miles. They replaced the front shocks, steering dampener and did a front end alignment. It went away, but now it is back.
It is odd, but now mine tends to bounce more if I am going around a slight curve and hit bumps. I have rotated the tires frequently trying to figure out if it is tire balance, etc - but it doesn't matter what the tire configuration is.
I pulled my Ranchos off at 6k and they were junk, these model shocks were definitely not designed for these heavy trucks.
