temperature gauge and fuel gauge not working
hi guys i have a 1971 ford 3/4 ton truck i just replaced the fuel sending unit in the tank and it was working the gauge and the sending unit and the temperature gauge was also working now i dont have temperature or fuel gauge working any ideas would be greatly appreciated thank you
on
IIRC, the CVR works with either instrument cluster, and it's the prime suspect.
Also, do you have dual tanks? If so, there's a tank selector switch that feeds the signal from either tank sender to the sole fuel gauge.
It's possible (but not likely) that you have two problems. If R&R -ing the regulator fixes both problems, you've got it licked; otherwise, you'll need to do some more sleuthing.
on
LMCTrucks.com has it for $50. I was looking at it today... I need one too
EDIT:
Page 79, item 34 for years '67-'69 $30
Page 79, item 35 for years '71-'72 $50
That lets me out, I need the one for 1970! (sheesh!)
on
Had to pick my son up from High School before I could get the instrument cluster reinstalled. When he noticed the big gap in the dashboard, he said "Ok, THAT's casual!" I then explained to him that there's a lot of stuff that you don't really need in order for the truck to run.
It made me wonder - Will the new trucks run if you remove the instrument cluster, or does the computer freak out and choke up?
on
when grounded. Best to have a helper so you can watch the gauge..
So replace sender if gauge is good.
Orich
japrine
12-20-2014 11:09 AM
