Hello,
I am putting a new engine in a 2000 Ford ranger. It has the 4.0. I had to install a new crankshaft angle sensor but i was wondering if it is timed to the engine like a distributor would be? I believe it is a crankshaft angle sensor. It is at the very rear of the engine top and is held down like a distributor would be.
If this goes in like a dist does, I would assume it would need to be timed in much the same manner. I'm not very familiar with this engine, so I can't say for sure.
I was assuming that it is like a distributor and your timing is set off of it. However i am not 100% sure. I bought a used engine to put in the truck for now and i had to change that over because the plugs are different on the top. Now i am wondering if i have to set it top dead center and start all over. I marked where the origional one came out but i do not know if swapping in a whole new crankshaft angle sensor will have to be timed. Thanks for the help.
