Valve cover gasket ?
Old 11-08-2011, 07:48 PM
teamgsxr's Avatar
teamgsxr
teamgsxr is offline
Is it possible to change the passenger side valve cover gasket on a 2003 f250 without tearing half the motor apart ?
I have a leak on the bottom rear corner. I washed the engine top and bottom and its starting to leak after 1000 miles out of that corner.
Thank you in advance.
Old 11-08-2011, 08:14 PM
zhilton's Avatar
zhilton
zhilton is offline
For more room...you'll have to pull the CAC (turbo to intercooler) tube, heater lines and glow plug controler. Much easier on the odd side (passenger) than the even (driver) side of the engine. Or at least IMHO.
Old 11-08-2011, 08:27 PM
bodabdan's Avatar
bodabdan
bodabdan is offline
I just had mine off for the first time. I found it very helpful to use a flex-head gear wrench to reach the ones closest to the evaporator housing. It's easier to get them from the bottom than it is from the top IMO. Your gaskets should be reusable, may just need to snug it a little.
And yes, definitely pull the CAC tube and wahtever else is in the way. You'll be glad you did.
Old 11-09-2011, 09:29 AM
cartmanea's Avatar
cartmanea
cartmanea is offline
Try just torquing it to spec. The gasket is reusable and very durable, so I doubt it is damaged.
Old 11-09-2011, 09:32 AM
teamgsxr's Avatar
teamgsxr
teamgsxr is offline
This weekend I will loosing all the bolts and retorque them as you guys reccomend. I will give that a try first.
thanks again.
moveoverGM
21
06-13-2018 11:04 AM
Todd Meinders
1997 - 2003 F150
12-16-2017 02:38 PM
reggiedunlop
1983 - 2012 Ranger & B-Series
10-23-2016 06:33 PM
R1racer
13
04-16-2015 12:31 AM
Chrisdrm10
07-31-2012 09:15 PM
Quick Reply: Valve cover gasket ?
