EFI or carb?
#32
I've always been partial to carbs,but I put this 1990 5.0HO out of a wrecked mustang with a AOD and I find myself driving this car ALOT even though I built it for my wife,LOL It runs awesome with NO issues.It's in my 57 wagon.
Joe
Uploaded with ImageShack.us
Joe
#33
Joe
Joe
#34
I remember back in the mid 70's when electronic ignition came out, I was an apprentice at a local garage. The 2 mechanics I worked under were just terrified when they were introduced to it. I was young and eager to learn so it really wasn't a big problem. The same goes for efi, it's been around for a while and has proved it's worth. How many guys are still running points in their ride because they're afraid of electronic ignition?
#36
I went with a carb just for simplicity's sake. One fuel line and a mechanical fuel pump. I'll always consider swapping to efi, but I probably won't ever bother. I must admit, I've only had one other carb equipped vehicle in the last 20 years so I'm used to the smooth running of efi, but I'm just not interested in setting up efi. The carb was just easy.
#37
I like efi it certain circumstances but in general I prefer a carb. I love electronic ignition and only run points if I have to. Installed a petronix unit in my truck and love it. Wanted to go a true hei but nothing for 6v and I am not changing it over. I think it adds so much character having a flathead and 6 volt.
#38
When I built the '63 Falcon last year, I ened up using a '91 5.0 HO, completely gone through, and an Edelbrock Performer RPM clone intake. Ran BBK headers, and dual 2.5" exhaust. I made the engine look completely stock, except for the Professional Products EFI on top. I installed a T-5 from the same Mustang, and ran it to a '63 Sprint 8" rear end. I ran a MSD 6AL box, and the Professional Products HEI type distributor (the GM looking one for Fords). I ran a Ford Racing King Cobra clutch kit, and it couldn't handle the mostly stock 5.0. The EFI was easy to install, was totally self contained, and easy to base tune with a lap top. It was a returnless system, and it self tuning during drive time. After getting the clutch dealt with, I could roll down the road at 15-20 MPH, mat the throttle, and smoke the tires. The response is phenominal, and blows a carb away anytime. With carbs, it is difficult to get everything tuned just right (you know, that nagging little dead spot that lasts for about .025 seconds when the throttle snaps). EFI vs. Carb....there are more pros for EFI than for carbs. With modern fuels, the carb needs to be refurbed with Viton seals, and such, EFI is modern fuel compatable, right out of the box. When building the Falcon, I had three options.....carbed 5.0, Ford EFI top end, or the PP EFI kit. Personally, I won't use anything but an aftermarket EFI on any future street rod builds. Carbs are junk, and OE EFI is not worth the effort, dealing with all the transplanting crap. If you haven't tried an aftermarket EFI set up, you're missing out, in my opinion. There's plenty of photos in my photo bucket of the stock looking 5.0, topped with EFI.
#39
#40
Received 4,195 Likes
on
#41
I installed it myself, and whatever the cost of the kit is now. If you have a truck, that is ready for induction, it's as simple as buying the kit, taking it out of the box, and following the directions for installation. The doesn't include the fuel pump, but a combo kit is available that does. It's not much more. Install the fuel pump (wiring leads are included), and install the throttle body. On Fords, with stock ignition switch, and starter solenoid, you MUST use the extra post on the starter solenoid for the computer "hot in crank" lead, or it will reset everytime you try and start it...I found that out the hard way. There isn't much to buy after the fact. I did, however, go with russell fittings, and such, so I had some extra costs. The new one is even easier than the one I used, which is no longer avaible except when you search online for some still in circulation. I was EXTREMELY happy with it. It made that little 5.0 come to life. It responded so well, had tons of response all the way to the chip I put in the MSD box. It would climb through the rpm range without a bit of hesitation, bucking, snorting, coughing, etc., etc. It started right up, warm or cold. The one I used, I could tune it a bit with the lap top. I could add a little extra fuel to the curve when I stomped on it with a little slider control, and I could add, or reduce fuel for cold start. I could adjust it by air/fuel ratio, or by fuel pressure, or by RPM, or what ever.
#42
#43
#44
I would like to go the EFI route. I am trying to come up with a reasonably priced EFI to mate with my 383HT sbc clone (Vortec heads). I have a hard time putting more into a fuel injection system than I have in my fully machined and rebuilt 383 (I am under $2K).
Sam is correct, my research agrees that the best way to approach an EFI motor fo your truck is to get a complete as built setup (motor with factory EFI) and do your best to clean it up. In my case I got the horse before the cart, i.e. built the motor planning carb (I have what I need for a carbed setup) but would like to go with an EFI. Lessoned relearned, make your plan and stay with the plan. Other options result in too many $!
