51 Panel - Still crazy after all these years!
#106
Gave the kid the welder, sawzall and nippers!
Cleaned out the panel, and cut out the rot. He welded in pieces to the rear of truck (no picts) and is ready to close up the floor.
He also did a little rust inhibitor and por-15 painting. No picts (yet)
#107
#108
#109
#111
#112
#113
Right now buried in crap, between work, gettin' the '50 inspected. (Brakes-rear, new donuts, replaced lower steering shaft and knuckles, converted to disks in front and still have to do kingpins! 3 weeks ago basement of shop took 8" of water and 1/8" of muck. Got partly cleaned out and hope to finish that today. This is where the '51 & '47 live. My son was also doing rear brakes, shocks and new gas tank as well on his car, so couldn't really clean agressively.
We kid is done and out, so another 1/2 dumpster of old wet laptop parts, wood and cardboard, hosing and brushing. Then I'll put the '51 back in, do the '50s Kingpins and maybe, just maybe... get back on the '51.
On a brighter note.. Have put 250 miles on the '47 going to a few cruises .
#114
Finally getting back on the '51....
Kingpins on the '50 a bitch, finally pulled axle and took to machine shop. Went back together great.
Did have a little fun going to some cruises:
Anyway..
Got the floor zipped up and POR-15'd
New seat in background. Also made the seat/console support:
Cleaned up the dash and door jambs, then shot them with some primer. Figure I'll paint that, drill holes for seat and console, lay carpet and install gauges and make sure stuff works electrically before I mount seats (but laying on the carpet will be so much better on the back! )
Anyway..
#115
#116
#118
Had some time over the weekend and got the doors shot and started reassembly. PO put in not 5-star lock mech. on drivers side. (Put in vent windows with new rubber, door latch and lock) In the midst of getting the correct one (with keylock). Also installed guages and got oil, water and voltage working. Haven't replaced gas tank yet.
Wasn't paying attention and now have a little overspray to clean up.
#120
Started working on the doors. Put in new stuff, installed window and made door panel out of individual panel pieces and stained them to sort of match the seats. (still need to poly the panels) Did the upper panel in black and after looking at it, I'm gonna 2-tone the dash (with black under trim - like a real 5-star should look.)
Also got the lower door seals installed. Waiting for the door lock mechanism to come, so I can't do the driver door yet.
Next I'll do dash and console. Then the lock should be here and I can do driver door.
P.S. I hate when you put in new door rubber seals and then the door thinks it's too fat to close. (at least for a couple days.)
I'm gonna do the panel's interior with the same wood that's on the doors.
