51 Panel - Still crazy after all these years!
So I thought about it, and prayed about it, and asked you guys about it. Figure I needed an enclosed vehicle for the business, as winter is coming and may have some projects (computer-wise) that would spill over into the bed of the '50. Probably not wise to put carboard boxes in 6" of snow :-X03.
So I bit the bullet and purchase a '51 panel delivery which I drove some 45 miles home. Had a couple little "Rattles" and the front end seemed a little mushy. $5k was the tag, and around here they get $2500-4000 for rusted "field finds". So here's the picts... http://www.computerliterates.com/47f...b/100_1113.jpg Face chrome pretty decent, and only surface rust on the nose. http://www.computerliterates.com/47f...b/100_1114.jpg http://www.computerliterates.com/47f...b/100_1115.jpg Surface rust on RB's. One of the almost impossible parts to find. Othe side had small hole and 2 misdrilled holes (pictured later.) http://www.computerliterates.com/47f...b/100_1116.jpg A little bondo bubble, but it appears metal solid, except the patch of the old (original gas filler tube. (I may resurrect this later). http://www.computerliterates.com/47f...b/100_1117.jpg Top of fender "soft" :'(. And too much bondo in back, but looked OK from inside. http://www.computerliterates.com/47f...b/100_1118.jpg Dash OK, chrome piece on floor, speedo works, but other guages - not so much }>:-X03:-X18 http://www.computerliterates.com/47f...b/100_1119.jpg Missing hood side trim ($$$), but has solid visor, new windshield and rubber. Doors are really solid, but needs driver window and new felt. http://www.computerliterates.com/47f...b/100_1120.jpg Passenger fender NOT happy :(, other side is faily new glass one. http://www.computerliterates.com/47f...b/100_1121.jpg http://www.computerliterates.com/47f...b/100_1122.jpg Passenger rear, a few bubbles, but not so bad. http://www.computerliterates.com/47f...b/100_1123.jpg Well, it has BOTH back doors. :-X22 Driver side rotted at bottom, but repairable, passenger side is solid. http://www.computerliterates.com/47f...b/100_1124.jpg http://www.computerliterates.com/47f...b/100_1125.jpg It also has correct rear bumper. http://www.computerliterates.com/47f...b/100_1126.jpg In it's history, someone put on wide tires and "tubbed" fender wells. Metal floor is pretty solid, but I think body has dropped about 3/4" in rear. Needs some investigation :-huh. Otherwise, besides cleanup, grinding and rust-proofing, interior not bad. (Except the '70s "headliner" stuff). Gas plumbing and old camero tank have got to gooooooo !}>. http://www.computerliterates.com/47f...b/100_1128.jpg http://www.computerliterates.com/47f...b/100_1127.jpg Upper body is nice and straight.. http://www.computerliterates.com/47f...b/100_1130.jpg http://www.computerliterates.com/47f...b/100_1131.jpg Here's the floor drop. Wood underneath metal. http://www.computerliterates.com/47f...b/100_1132.jpg Starting to strip front clip. And passenger fender is rotted :( http://www.computerliterates.com/47f...b/100_1133.jpg Has a GM FI305/R700 combo, with computer and wiring harness, steering column donated from a '80 camaro. (gas tank as well). 1990 Ford van 9" rear and '78 Ford LTD II front clip. I think front is a little soft cause the coils aren't strong enough for the V8 weight. Probably was the 6-cyl version of the LTD. Gonna strip the front clip, cleanup and make solid. Replace springs and "pretty up" the wiring. Not gonna be a showpiece, but more of a 3-day per week DD. Get bodywork started, cleanup interior, por15 it, new seats, figure out if body "sunk" are what's on the todo list. The '47 is gonna really be "pissed" at me. But I'll try to find some time... :-X21 P.S. Also has pretty new skins and I think I'll keep the color. |
Overall the panel looks pretty good.:-X22 Looks like it has some of the usual issues for that age truck.
They put in a Ford front clip and still put in a gm engine and transmission???:-X15 Why, why???:-X04 The 78 LTD II was the fullsize car. Basically same as the 70's T-birds. No 6 cylinders came in them. The smallest engine available was the 302 SBF V8. But most came with a 351M/400. The front springs are probably just worn out. Just swap in some new heavier/stiffer springs and you should be set.:D:-X22 |
I have trim and other parts for your Panel. PM or email me with your wish list and I'll try to fulfill it. :)
Welcome to the Panel Owners Club. It's a very elite club. Membrers Only jacket not required. :-X06 |
Originally Posted by 51PanelMan
(Post 11012452)
Started getting into the truck and the "value" went down a little. Mostly because a lot of shortcuts were made. In fact, after looking at it, I'm surprised it made it home. :-huh:p Well, the nose chrome shined up nice and is in great shape for a DD. The turn signals were shot and came off in little pieces of rust with a cover and lens. http://www.computerliterates.com/47f...b/100_1134.jpg Started tearing down the front clip. And yes, the radiator was sitting on some homemade pieces of rubber padding, and held in place by the radiator hoses ! :-arrgh:(:'(:-X18:-X18:-X18 http://www.computerliterates.com/47f...b/100_1135.jpg The sheet metal was faily solid, except for pass. fender. I don't think the pass. inner fender is attached to anything but the fender ! I'll find out later today. :-X21:-X18 Pulled tires, set up jack stands, fenders next, then I'll show some more HORRORS !!}>:'(:-hair |
Got a little more done, now honeydo...
Removed some more sheet metal, pulled the radiator, Tranny cooler siliconed on, fan on radiater with two wire zip ties, at least fluid in radiator! :-X03. Frame appears solid, but needs some TLC. http://www.computerliterates.com/47f...b/100_1136.jpg OOPS ! Someone cut a notch out of the frame :-arrgh. Maybe it had a SBF with front pan in a former life?? Guess I need to weld that up to keep the wheels on (or a least in alignment :-X03) http://www.computerliterates.com/47f...b/100_1138.jpg |
I see mine wasn't the only truck to have some "P.O. Butchery".:-X04
Stuff like that makes a person think "what in the hell was the previous owner thinking when they did that"!:-roll He must have been partially crazy! After all he did swap in a cheby engine!!;):-X18:-X04:D:-X03 I'm not sure why they notched the crossmember. I'm pretty sure the LTD II's came with a front sump oil pan on the engines. Unless someone swapped in a deep sump racing oil pan and needed the room.:-roll:-X15 Looks like you've got some work to do on this one. |
Yeah... PO Butchery...
Well tryin' to get this on the road quick, but safe. Can fix other stuff as I go. Finished stripping front clip, degreased engine, pulled non-functioning air pump and AC comp. Rattle canned top of engine and cleaned up, rattle canned firewall. Started pulling apart suspension. Replacing all bushings, ball joints, coils and shocks. Need to test front calipers. Bought POR-15 basecoat and chassis black. Will do that after I finish pulling control arms and welding up x-member. Here's a couple progress shots... This will be a doer, not a looker (but the body should still look good :-X22) http://www.computerliterates.com/47f...b/100_1155.jpg http://www.computerliterates.com/47f...b/100_1159.jpg |
Making it safe is a good plan!:-X22
Ford blue on a chevy engine??????:-hair:-X15:-X04 Oh the humanity!!!:-X04;) What's next Ford valve covers??:D Man you are really tearing into it!:-X22 It should handle and ride like a dream with all the new suspension parts.:-X22 |
Ted, thanks for paying attention to me. I thought I may have Forum BO. :-hair:-X18:-X16
Yeah! Ford Blue, can't afford to change it, so I'll hide it from the unwashed masses! }>:-X03 P.S. A big enough air cleaner can hide almost anything!!! |
Originally Posted by COMPLIT1107
(Post 11063091)
Yeah! Ford Blue, can't afford to change it, so I'll hide it from the unwashed masses! }>:-X03 P.S. A big enough air cleaner can hide almost anything!!! No problem!:D The only thing that stinks around here is the lack of progress I'm making on my project!!:-X04 Seeing all you guys making so much progress on your projects here gives me a little hope that someday I may actually do something on mine.:-X04 At least you didn't paint a SBF cheby orange!!:-X24 :-X04 That better be one large air cleaner!!!;) :-X04 |
(Post 11062079)
Haven't found the "big" air cleaner yet! But, managed to squeeze in some hours over the Thanksgiving weekend.
Cleaned up, POR-15 and chassis-blacked the components and picked up the new bushings, ball joints, shocks and springs. (NAPA) http://www.computerliterates.com/47f...b/100_1161.jpg Then did the frame (up just past the weld point of the 78 ford to 51 frame). http://www.computerliterates.com/47f...b/100_1162.jpg Even though I wore rubber gloves, I still proved the point that POR-15 has to grow out off you skin, cause nothing removes it! :-X03 Got really energetic and got the driver side mostly back together, and the passenger side almost.. http://www.computerliterates.com/47f...b/100_1163.jpg http://www.computerliterates.com/47f...b/100_1164.jpg And since timing is everything, the "new" radiator support showed up.:-X22 http://www.computerliterates.com/47f...b/100_1165.jpg Now Ted coined the phrase "PO Butchery" and thinking back as I tore the nose off, there was no radiator support, the fronts of the inner wells were hacked to fit a wider radiator and had no front frame support. I guess the only thing holding the front clip on was the cowl bolt on the inner fender and the fender to running board bolts. THE REST WAS GRAVITY (and the hood being closed !!) :-X19:-arrgh:-hair:-X18:'( The only good thing was (in the 2nd pict) there is a big angle iron (in front of the crank pulley) which is drilled for the rad. support. I haven't measured yet, but hopefully it is located vertically and horizontally correct. At least the PPO (Prior Previous Owner) appeared to do things correctly and solidly. I also welded in angle iron where the x-member was notched. |
Everything back together, brakes tested, and wheels on...
http://www.computerliterates.com/47f...b/100_1166.jpg On to the body. Couldn't resurrect the inner fenders, cause the "bump" for the radiator support was cut out, but I found a decent set on ebay for a great price! :-X22 Separated the lower fender and found (after all the bondo was gone, that except for a cracked seam and a little "rough" area it was in pretty good shape. http://www.computerliterates.com/47f...b/100_1167.jpg The fender needs some TLC, as I spent my $ on a metal shearer (hand held) instead. The fender well was cracked and welded back up. I marked off what I needed to cut out and put the shearer to it's test. Worked great, maybe no more sliced fingers! }> http://www.computerliterates.com/47f...b/100_1168.jpg Cut a new piece and used my limited welding skills.:D:-X03 http://www.computerliterates.com/47f...b/100_1169.jpg http://www.computerliterates.com/47f...b/100_1172.jpg A little more hammerin', weldin' and grindin' and I'll have something to support a skim coat of the dreaded "bondooooo !!" Still have to cut and wrap it, just like a butcher. Or maybe that's what I am to the truck ?:-huh:-X18:-hair |
Naw sounds more like the PO was the butcher.
Looking good!!:-X22 Gotta love the POR15 too!:D Just consider any of it you got on your skin as a little body armor until it wears off!!:-X04
Sounds like you are finding some good scores on the used parts.:-jammin I'm pretty surprised that your lower fender is in that good of condition with all that bondo it had on it! Your patch is looking good so far. You might have fun forming that curved lip on the edge. I think I would have bought the patch panel for that area myself.:D You'll probably have to make a bunch of relief cuts in the area you'll need to fold over. And then weld up the relief cuts once everything is where you want it. Either that or cut the curve out of the patch to get the shape of the edge. Then cut out a strip of steel the width of the lip area. Form the correct curve you need and then just weld the strip to the fender. No matter what it's going to be fun!!:D And your not a butcher! I'm a butcher!!!:-X04 |
