2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Very odd hum/whistle
Old 10-30-2011, 06:47 PM
eddiemoney's Avatar
eddiemoney
eddiemoney is offline
Very odd noise, need some help figuring out if I need to attempt to have the dealership recreate.....could be a long process.
2010 22K miles; EL 4x4
When driving on interstate (anywhere between 60 and 75) at times a hum will start (probably every third trip). It sounds like it comes from the passenger side. Its reasonably loud. When I accelerate hard it goes away, when I coast or have really light acceleration it comes back. Its a solid hum/whistle...it doesn't change pitch.
Any ideas? Anyone seen something like that?
Old 10-30-2011, 07:54 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
check that your e-brake is releasing
4x4? if so, check that your auto hubs aren't engaged. if the vacuum line or solenoid fails your hub will engage (auto fail position is engaged)
best of luck. I know how annoying it is to try and track down a noise
Old 10-30-2011, 10:00 PM
eddiemoney's Avatar
eddiemoney
ebrake is releasing, i can hear that.....
Last 4x4 I had before this one was get out of the truck and turn the hubs...how in the world would I check to see if the hubs were engaged?
Old 10-30-2011, 11:06 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
jack up the front of the truck with the motor running
spin both of the front tires. if the front driveshaft rotates, or tries to...it means you have a hub that is failed, or the some part of the vacuum system has failed.
after you hear that noise, pull over really quickly and do a touch test of both rear rims. if the e-brake is dragging on either rear wheel, the rim will be rather hot. You may hear 1 side dis-engage, but it's better to be for certain. the 07+ Expy is based on the 04-08 F-150. The 04+ F-150 has a bad habit of having the rear e-brake freezing up.
Old 11-04-2011, 12:54 PM
TFWcustoms's Avatar
TFWcustoms
TFWcustoms is offline
What i had happen with mine was that the rotor cover was rubbing against the rotors, this is caused if you recently swapped tires and the cover was slightly bent. All you have to do is hit it hard enough back
ampslw
1999 to 2016 Super Duty
01-21-2011 11:02 PM
roxyrose08
2004 - 2008 F150
08-14-2010 08:13 PM
jdecker
1997-2006 Expedition & Navigator
11-02-2008 09:56 PM
kdbbmanton
2004 - 2008 F150
22
01-15-2008 11:58 AM
liquidc11
2004 - 2008 F150
06-27-2006 07:15 PM
Quick Reply: Very odd hum/whistle
