6.2L V8 Discuss the 6.2L V8
2011 SD250 6.2l bobo
Old 11-01-2011, 07:58 PM
stewy_56's Avatar
stewy_56
stewy_56 is offline
Hi,since new my SD trannny lets go between 2nd/3rd or 3rd/4th,engine overrevs
and cuts off for 1to3 sec.
Happens mainly when warm and after a stop over of 10 min.
Its tricky when taking off a busy intersection, even dangerous
Ford dealer says three other SD6.2l as the similar problem.they are putting recorders in some to try to find the problem
Any input from this forum may help
Thanks
Old 11-01-2011, 08:22 PM
nico963's Avatar
nico963
nico963 is offline
Thanks
You'll get more help if you scroll farther down to the 6.2L fourm.Those guys will beable to point you in the right direction.There is a TSB and a fix for your trans.Depending on your build date Ford will put new solenoids in the trans to fix the erratic shifts.
Old 11-02-2011, 07:36 AM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 6.2L V8 forum.
Old 11-02-2011, 08:13 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
Thanks
Print out the attachment below and take it to your dealer.
The TSB in the attachment was superseded by TSB 11-06-11. Nothing changed with the procedure though, just the wording in the title and issue statement
File Type: pdf
Old 11-02-2011, 01:55 PM
fz1dave's Avatar
fz1dave
fz1dave is offline
Super Duty
Yep, it's completely curable. Don't sweat it!
Old 11-02-2011, 04:55 PM
stewy_56's Avatar
stewy_56
stewy_56 is offline
sd6.2 bobo
Build date 02-11 selenoid change may not apply. but now I know they did a reprograming because after the 16000km service I was told to be harder on it,they blamed me to drive it like a grampa(witch I proudly am).
But why would the engine cut off?
My feeling is: On certain motobike there is a engine cut-off at shift point,
would this model have this feature???
At shift point there is always a hesitation as if the engine cut-off followed by a hard shift maybe caused by the engine miss-fire????
Tomorrow Ill be at the dealer with the TSB
Thanks Guys
IRONTEK
1999 to 2016 Super Duty
04-03-2015 01:53 PM
bememe
Escape & Escape Hybrid
04-06-2009 05:13 PM
6speed_whistler
Washington Chapter
27
03-08-2008 11:52 AM
twtchy3
2004 - 2008 F150
03-02-2005 07:29 AM
jjbrew86
06-08-2004 10:49 AM
Quick Reply: 2011 SD250 6.2l bobo
