Hubs, brakes and bearings, some questions:
Warn Industries - 4WD Hubs: Premium Hubs
All WARN Premium Hubs feature:
- 9/10 turn dial for robust engagement/disengagement
- Heavy detents for positive engagement
- Wave spring technology increases reliability over standard coil springs.
- All metal construction
- ZA Alloy dial with dual seals keep contaminants out
All that plus they have a limited lifetime warranty. I like the 9/10th turn to engage, my superwinches only have about a quarter turn. Plus they feel loose, but mine could be worn. I will def be going with the premiums especially since there only appears to be about a $25-$30 difference.
Does anyone have the Spicer number for the U-joints? based on the numbers posted by NW these are: 1310 U-joint = Spicer 5-153x / 5-260x / 5-278x according to this link: Part Numbers
Ok have all of my parts and ready to dive in and I found that the rear output shaft seal is bad as well and I have the ATF all over the under carriage of my truck. well it is good to get it all done at once and before the white stuff starts to build up.
And thanks for clearing up the D-44 questions.
badger_hound
21
08-19-2012 01:14 PM
Groundpounder0331
13
05-25-2010 09:32 AM
omni
07-04-2006 07:22 PM
86 Windsor
09-24-2004 01:34 PM
botz
11-27-2003 08:33 AM
