watson Aux in a dent
That's the way mine works. When I tore it apart there were small spring loaded detent ***** that locked the shafts in the different positions. I could only get them to go into 3 positions until I hot tanked all the parts. By the way, those springs and ***** were a real $%%^^^^ to get back together........
thats the general consensus i hear .... mine also had 2 bolts that "lock" the shift rails when you screw em in just wondering what these are for? also mine had water in it, no rust but its sludged to death id like to wash it out and run it as is after new seals i have no intentions of a rebuild until i run it to see how things go. its verry tight and turns smoothly .
what can i wash it out with that wouldnt furthur ruin any seals ? my uncle sugested filling the case with kerosine over night and repeat a couple times along with turning the sharts and shakeing the box itself to loosten up the gunk
UPDATE: this week i took off both the pto cover and the large acces cover and put it in a bucket made from the lower third of a 40 gallon drum i filled it with kerocine and it washed all the gunk out almost instantly i rinced it several times and finaly submerged it overnight it looks realy good inside and shifts nice too! im still haveing trouble getting the outside clean enough to paint
what type of seals does this unit have and can i convert it to the neoprne seals like in a axil hub?
also what size U joints does my 1ton have in it? everythign is stock? and it has the np435
Eh... the nuts on the u-bolts that hold the u-joint to the rear yoke, should be 9/16" if its 1350 joints. The joint at the trans may be different tho. Hard to tell what all they did. I was trying to find a t-case yoke and everyone was just like... have to bring it in, theres no tellin what was in what. But i assume you have the D70 rear, so im betting 99% odds that its a 1350 in the back.
#29
Here's some info on universal joints I saved from another forum, -Understanding Universal Joints and Size Charts, this will have the info your looking for, its all the way at the bottom of the page.
#30
