Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
f700 weight
Old 10-24-2011, 08:12 PM
sth62691's Avatar
sth62691
sth62691 is offline
f700 weight
anyone have a guess at the actual weight of my truck for towing reasons? 1987, f700, 6.6, diesel 5 speed, no pto, day cab, chassis cab, full 50 gal diesel tank, air breaks, relay need a good guess of the actual weight thanks guys
Old 10-25-2011, 12:49 AM
80broncoman's Avatar
80broncoman
80broncoman is offline
All I can tell you is that the 94 F700 that I have weighs very close to 10K.
That weight was as a chassis cab. Factory double frame, 5.9 cummins engine, 6speed eaton, 22K rated rear axle, 10K front. air brakes, full 50 gallon fuel tank. 196 wheel base.
hope this helps.
Old 10-25-2011, 06:14 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
The Certification Label will have the GVWR (Gross Vehicle Weight Rating) printed on it.
The 4th digit of the VIN defines the GVWR even further.
Old 10-25-2011, 01:00 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
He's talking tare weight.
Old 10-25-2011, 01:11 PM
NumberDummy
Correctamundo, but the only place the OP can get an accurate weight, is at a truck scale.
There's a gazillion differences between truck models, years, powertrains, fuel tanks, "back of cab" equipment and et cetera.
So, guessing what the weight could be, doesn't cut it.
Old 10-25-2011, 01:26 PM
85e150's Avatar
85e150
You're right, the air breaks could make a big difference.
Old 10-25-2011, 01:31 PM
NumberDummy
Originally Posted by sth62691
air breaks.
That's the breaks...or is it brakes?
The most commonly misspelled word associated with vehicles on FTE is brakes.
Old 10-26-2011, 02:08 AM
rummur s.c.'s Avatar
rummur s.c.
rummur s.c. is offline
Oh give me a break.. HAHA
lets just say the truck weighs between 8000 and 12000..
If you need a more exact number, you really should just drive her down to your local scale.. (I suggest you wait till they're closed if its a DOT scale) Sneak onto your local transfer station scale.. strap some garbage cans to the back. Thats how got the scale weight dropped on my 800 truck. It was a crane for its first 30 years then it got down sized to mechanic truck.. Much lighter.
Old 11-01-2011, 09:13 PM
CF LN7000's Avatar
CF LN7000
CF LN7000 is offline
I have a 1990 workready catolog and in 1990(dont see too much of a difference from 1987 to 1990) there were 3 F700's offered with that drivetrain combination. One had a 24,500 GVW, 153 WB and chassis weight was 9,170 lbs. Next was 28,000 GVW, 153in WB and chassis weight was 9,040 lbs. Last was was 28,000 GVW, 207in WB and chassis weight was 9,531 lbs. Hope this helps
bardave
General Diesel Discussion
25
02-22-2013 10:27 PM
f350rebel7788
05-17-2011 07:38 AM
Whippled04
1999 to 2016 Super Duty
01-21-2007 03:08 PM
Dubra
03-14-2004 09:45 PM
mikeartb
01-18-2004 12:00 AM
Quick Reply: f700 weight
