$1500
10-23-2011, 05:52 PM
on
$1500
Well I spent $1400 on some Yukon shafts and super joInts for the Dana 60 and it don't fit the yokes are to big can't even take the knuckle off and wiggle and twist it together I'm not a happy camper
10-23-2011, 06:05 PM
on
Wait... im confused. You can't get the stockers out of the spindle hole on the knuckle?
Or you can't get the new ones IN the spindle hole of the knuckle?
10-23-2011, 06:51 PM
on
The new ones won't fit inside the knuckle hole I even broke loose the ball joints and tried sticking axle in first then knuckle and a no go.
10-23-2011, 07:01 PM
on
Interesting.... go to Pirate4x4 and ask this question in the Ford forum. I remember seeing a thread about this a while ago. Don't remember the solution.
10-23-2011, 07:21 PM
on
I see a grinder to cut nothes in the hole but they was sold as fitting units I'll be calling east coast gear supply in the morning
10-24-2011, 08:15 PM
on
Well the solution was to use a grinder to shave off some of the ear on the axle shaft and Yukon still said lifetime warranty is good
10-25-2011, 06:54 AM
on
As long as they said the warrenty is still good, they're probably aware of this issue.
Grind away. Must be some big yokes on them things. I know the stockers are somewhat tight when they slide in or out.
What did you do for inner axle seals? Ever consider those new outer axle seals? I see them working good on new shafts, but not old rusty ones.
10-25-2011, 11:23 AM
on
I had some outer axle tub seals on it put them in about 6 months ago and they are ate up and I havent found a solution yet
10-25-2011, 06:34 PM
on
You think the new shafts will eat them up?
10-25-2011, 07:14 PM
on
I don't think the mad dog outer axle seals are a good product. I'm just gonna leave the old seals in it and see if the new axle shafts last
akguy09
04-14-2015 03:21 PM
RCrawler
03-20-2012 12:33 AM
Bender99
Offroad & 4x4
12-06-2009 01:12 AM
osteo16
1999 to 2016 Super Duty
06-10-2009 12:28 PM
69crewcab
07-14-2003 09:23 AM
