ok i have a 92 f250 4x4 with 351w and e4od tranny going to switch it over to MAF found a truck in the local bone yard that is a 94 f150 5.0 with e4od tranny that has MAF the questions i have are what do i need off this truck and will the 5.0 stuff work i know i need both computers 1 for the e4od and 1 for the motor thanks
I would grab as much of the engine harness as you can. They have a 351 MAF Computer but I think is was for Cali only. The Motor and trans are all in 1 ECU.
ok so if i get the ECU and the injector wire harness and all the stuff from the air box to the TB i should be ok ? and then all i would have to do is put it all on my truck and be good to go ? sorry just want to make this as easy as possible
