6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 11-19-2014, 01:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
  • Safety Features
    Important information to help you understand your Ford truck
Browse all: Brake Guides
Print Wikipost
stop safely now
Old 10-22-2011, 06:06 PM
KHADIJE22's Avatar
KHADIJE22
KHADIJE22 is offline
stop safely now
i was driving my 08 f350 6.4l diesel speed 50 km/h
when the stop safly now shows up at the massege center
then the vehicule slows down the gas pedale does not respond ,i stopped it turn it off then won't start again.after one hour i tried to turn it on it run for half an hour then the massege shows up again and the thuck slows down.....
does that happen to any one else ?
please let me know how did you fix that?
which part did you have to change?
thanks
Old 10-22-2011, 08:22 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 6.4L Powerstroke Diesel forum.
Old 10-22-2011, 09:14 PM
66stang351's Avatar
66stang351
66stang351 is offline
That is a safety feature to protect the engine from more damage caused by a failure of some sort. Recommended action is to get it towed to a dealer for diagnosis and repair.Do NOT keep driving it with this condition.
Old 10-23-2011, 03:29 AM
Larry NCKS's Avatar
Larry NCKS
Larry NCKS is offline
Yep! Too broad a spectrum of possibilities! Have someone read the codes. That'll tell you more than we can with the generic information you have.
I'll echo the don't keep trying to start/run/drive it like that!
Old 10-26-2011, 05:31 AM
golfmedik's Avatar
golfmedik
golfmedik is offline
My work truck did the same thing. It was an EGT sensor bad. 20 minutes to change it after it had been towed to the dealer.
Old 10-26-2011, 06:37 AM
KHADIJE22's Avatar
KHADIJE22
thanks everyone for the advises
after towing it to the dealer it was the egt sensors
good thing they are coverd by the warranty
nico963
6.2L V8
02-20-2012 05:44 PM
joshsim
10-21-2007 09:20 AM
kennedyford
Bio-diesel, Propane & Alternative Diesel Engine Fuels
12-30-2006 09:33 AM
mark land
07-22-2006 07:48 PM
Quick Reply: stop safely now
